Fisheye recommendation!
flowmotion
by flowmotion » Sun Jul 07, 2013 10:37 am
Hey Folks,
here comes a post, i normally comment in other Forums with "you pay peanuts, you get monkeys :D "
but that´s what it is about.
Actually i am shooting my panoramas with 24mm Canon lense. It works great. BUT I want to become faster - and the high resolution is not needed for the webprojects the panos are used for.
so i thought about a fisheye, where i can handle a 360 with 6 shots.
Lense for canon fullframe bodies.
And here the challenge: Is there a cheap lense out there, that offers acceptable quality?
HansKeesom
by HansKeesom » Sun Jul 07, 2013 10:42 am
flowmotion wrote:Hey Folks,
The new version of the Samyang 8 mm is very nice. Can be used on ff even. Optics are good enough, not as good as the expensive brands but you save a lot if money without loosing much in quality.
It is a manual focus lens though.
Regards, Hans Keesom
flowmotion
by flowmotion » Sun Jul 07, 2013 10:51 am
manual focus is ok at this focal length :)
i´ll search for it...
by mediavets » Sun Jul 07, 2013 12:15 pm
HansKeesom wrote:The new version of the Samyang 8 mm is very nice. Can be used on ff even. Optics are good enough, not as good as the expensive brands but you save a lot if money without loosing much in quality.
There's a new version?
What's different?
by klausesser » Sun Jul 07, 2013 1:13 pm
The best way is to look for a 2,8/15mm Canon fullframe-fisheye when you use a Canon FF or a Nikon 16mm fisheye when you are on Nikon. You can get the 15mm these days fo a very reasonable price because it´s out of production. The actual Canon fisheye is a zoom: 4/8-15mm. It provides surprisingly good image quality - but makes only sense whe you really need both focal-lengths.
The Canon 2,8/15mm fe and the Nikon 2,8/16mm fe need 5+Z shot @20% overlap resp. 6+Z @25% overlap. They´re very good and sharp lenses.
Using an 8mm fe on a fullframe camera in my eyes is pure nonsense - you give away lots of resolution . . which means image-quality.
I don´t know which camera you use. IF you use a DX camera i strongly suggest the Nikon 10,5mm - also on a Canon camera. I used it on a 20D for some time and it worked fine:
http://360impressions.de/Tower/
http://360impressions.de/Mini1.html
HansKeesom
by HansKeesom » Sun Jul 07, 2013 2:07 pm
What's different?
Mostly the fact you can take of the front so it becames a shaved lens. This allows it to be a bit more usefull on a ff body although with some quality limitations.
The lens/glass is also bigger compared to the previous version
Price is still really low compared to the best/greates/most professional lenses.
If one is starting and has to buy a lot of gear, this lens can help to stay within budget without loosing to much in quality terms
by klausesser » Sun Jul 07, 2013 2:52 pm
HansKeesom wrote:If one is starting and has to buy a lot of gear, this lens can help to stay within budget without loosing to much in quality terms
The very last device where a starter should save money definitely is the lens. The whole thing called photography starts with and depends on the lens.
Better save on the camera or something but on the lens.
HansKeesom
by HansKeesom » Sun Jul 07, 2013 3:16 pm
I helped a number of people to get started from scratch.
Advised configuration was then a manfrotto 150 euro tripod, Nodal ninja 4 with RD-8 /18 rotator, canon 1100D with 18-55 mm and this lens.
If you can show me where to shave off of some more euro, let me know.
