Is there any way to convert planar Gpix into HTML5?
Saulius
Likes: 4 posts
by Saulius » Mon May 27, 2013 3:15 pm
I am looking for some advise how to publish planar/cylindrical Gpix on HTML5?
...is this way to canvas image size up to 2:1 and restrict wiever parameters xml?
Thank you!
by klausesser » Mon May 27, 2013 7:06 pm
Saulius wrote:Hello,
Thank you!
Planar or cylindrical - you need to decide.
You can use up to 120 - 140° for planar projection - preferably Panini.
For cylindical you can have 360° - but you´ll have bent horizontals.
by mediavets » Mon May 27, 2013 7:24 pm
Thank you!
You could have to render as spherical and 'pad' it to 2:1 - but the HTML5 panorama viewer supplied with PTP 1.8 does not honour the virtual crop on the VFOV.
So it's a non-starter.
I believe the Gigapan site can now deliver HTML5 compatible views to appropriate platforms:
http://gigapan.com/cms/view
Or you might like to try this viewer and related tools:
http://www.bigmike.it/gigapx2pano/
http://www.dimin.net/software/panojs/
