Any idea why this happened?
TukulCR
by TukulCR » Fri May 03, 2013 12:11 am
I set a rectangle of 25 images on 6 rows but somehow papywizard decided to start shifting shots to the left. Any idea why does this happen?
Your insight will be very useful thanks
by klausesser » Fri May 03, 2013 12:18 am
TukulCR wrote:http://www.virtualtourscr.com/images/kolorforo.jpg
Seems you didn´t really shoot a rectangle . . ;)
If PapyWizard or APG would make an error the house wouldn´t be stitched correctly. But it seems to be correct!
Tell us how you did the shooting in detail, please.
Wich kind of head did you use? Which pattern?
by mediavets » Fri May 03, 2013 8:17 am
TukulCR wrote:I set a rectangle of 25 images on 6 rows but somehow papywizard decided to start shifting shots to the left. Any idea why does this happen?
Trying disabling 'Alternate drive' in the yaw and Pitch plugins.
It will be slower to shoot but as I recall it will avoid the'stepping' issue.
Alternatively consider purchasing the T&C Toutch controller for Merlin/Panogear.
claudevh
by claudevh » Sun May 05, 2013 8:30 am
Check the tension of the bolt into the battery compartment, this is maybe too loose !
Could you turn the head freely with your hand ?
If yes the bolt is too loose ...
:cool: Claude :cool:
zauberer152
Re: Any idea why this happened?
by zauberer152 » Thu Dec 25, 2014 6:42 am
Also can't understand, what is incorrect? (see attached file)
panogear.doc
(1.17 MiB) Downloaded 346 times
