New Android Application for controlling Panogear Head
AlexKuro
by AlexKuro » Thu Apr 25, 2013 4:02 pm
Recently I made a simple application for controlling panogear from mobile phone with android (>2.2) OS.
Right now it can work with papywizard xml presets only, but it fully meets my needs at this moment.
So i decide to open its source and share it with you.
https://github.com/snable/paShoot
Read instructions to run it.
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Thu Apr 25, 2013 4:32 pm
Hi Alex,
you say it works with papywizard xml presets. So everybody who uses your app needs pattern:
http://www.wackel3d.de/shootpatterngenerator.aspx
greetings from gemany
Chris
Mateusz Malinowski
by Mateusz Malinowski » Thu Apr 25, 2013 6:13 pm
I tried use app on sony ericsson xperia mini pro Sk17i rooted android 4.04
- instalation - ok
- open app - ok
- connect - ok
- shott - app has stopped (yes, I paired Papymerlin, create "panoShooter" folder on sd card and copy preset.xml)
AlexKuro
by AlexKuro » Thu Apr 25, 2013 7:17 pm
What you saw at right-bottom corner of application window?
Is path to file (you can see it at the center of screen) correct?
Is this application ( https://play.google.com/store/apps/details?id=com.skywatcher.PanoramaApp ) works?
Is red LED on Panogear bluetooth flashes or lights after connecting?
It was tested on HTC Wildfire (Android 2.2.1) and Samsung GALAXY Pocket S5302 (Andoid 2.3.6) and works ok.
Unfotrunately, android emulator won't work with bluetooth, so i can't test it with higher versions of android right now.
Mateusz Malinowski
by Mateusz Malinowski » Thu Apr 25, 2013 9:03 pm
When only touch shoot button app has stopped and i don't see any changes in right-bottom corner. But if select : connect-stop there is "service discovery failed" .
See screenshots.
I don't see any path to file.
Is this application ( https://play.google.com/store/apps/deta … anoramaApp ) works?
Yes
I use papymerlin and there is green led. When disconnected - flashes, when connected continous light (in panoramaApp and panoShoot)
AlexKuro
by AlexKuro » Thu Apr 25, 2013 9:39 pm
Sorry, definitely my bad.
Directory must be named "panoShoot" instead of "panoShooter". ("paShoot" now)
Rename and send me feedback, please.
Mateusz Malinowski
by Mateusz Malinowski » Fri Apr 26, 2013 9:28 am
Yes - now it work.
AlexKuro
by AlexKuro » Fri Apr 26, 2013 11:17 am
Good news :-)
mallik
by mallik » Fri Apr 26, 2013 1:57 pm
Hi im using the panoshooter on samsung galaxy tab2 ics 4.0.
Nothing is happening when i press shoot its getting disconnected n im unable to access any settings.
AlexKuro
by AlexKuro » Fri Apr 26, 2013 4:55 pm
Did you turn on bluetooth?
Did you pair papyMerlin device on bluetooth settings?
What you saw at right-bottom corner of application window after pressing "connect?
Is LED on Panogear bluetooth flashes or lights after connecting?
mallik
by mallik » Fri Apr 26, 2013 5:43 pm
Hi
All your question check list is working fine, after connecting when I press shoot- the bottom corner shows 0/0 but the head is not rotating, then disconnects n again shows connect option.also im unable to access the settings nothing is displayed. panorama app is working fine.
I use panogear purchased a month ago, is it differnt from papy merlin n is that the problem.
AlexKuro
by AlexKuro » Fri Apr 26, 2013 5:58 pm
Probably your preset file incorrect. Can u show it? Try this one - https://raw.github.com/snable/paShoot/master/EXAMPLE/preset.xml
Make sure that file encoding is UTF-8.
mallik
by mallik » Sat Apr 27, 2013 3:56 pm
Hi now its working the pashoot.apk, but no settings access. How can I enable bracketing?
AlexKuro
by AlexKuro » Sat Apr 27, 2013 9:05 pm
There are no settings and bracketing support. Maybe I or someone else (source is open) will add this feature later.
