bluetooth connection problem
mallik
by mallik » Fri Mar 15, 2013 7:39 pm
Hi I'm experiencing problem with the blue tooth connection transmitter/receiver. I have paired the panogear with my laptop to work with papywizard, it connected successfully n I tested it completely everything worked fine pan/tilt shutter, trigger, bracketing etc. Today I wanted to shoot a test panorama, papywizard is crashing when I click the connect, I have tried repairing but not succeded.please help to fix it.
Windows7 x64
I5 processor 2.4ghz
4gb ram
by mediavets » Fri Mar 15, 2013 8:50 pm
Try a serial connection (via Bluetooth) instead.
Look at your Windows Bluetooth config. to determine the virtual COM port assigned.
then configure a serial connection in papywizard. Serial port values may be enmeterd as '0', '1', '2', '3' etc. or 'COM1', 'COM2', 'COM3' etc.
Papywizard enumerates serial ports from 0 (zero) so you may enter '1' or 'COM2', '2' or 'COM3', and so on.
mallik
by mallik » Sun Mar 17, 2013 9:24 am
mediavets thanks its working again.
