Control Panogear from Stellarium?
aaronpriest
Likes: 4 posts
by aaronpriest » Sat Mar 09, 2013 8:03 pm
I have a Panogear with bluetooth module and it works fine from my laptop via Papywizard. Is there anyway to use it with Stellarium over bluetooth? I'd like to track the Pan-STARRS comet with a telephoto this weekend and shoot it. I don't have the GOTO controller. I've been unsuccessful getting Stellarium to communicate with the Merlin/Panogear.
by mediavets » Sat Mar 09, 2013 8:28 pm
aaronpriest wrote:I have a Panogear with bluetooth module and it works fine from my laptop via Papywizard. Is there anyway to use it with Stellarium over bluetooth? I'd like to track the Pan-STARRS comet with a telephoto this weekend and shoot it. I don't have the GOTO controller. I've been unsuccessful getting Stellarium to communicate with the Merlin/Panogear.
I can't see that Stellarium has anything to do with controlling astrotelescope mounts.
Is this the software you are referring to?:
http://www.stellarium.org/wiki/index.php/Introduction
Perhaps you need something like this software?:
http://www.ursaminor.hu/ursaminor_introduction_en.html
aaronpriest
Likes: 4 posts
by aaronpriest » Sat Mar 09, 2013 9:32 pm
Sure Stellarium does! Been a plugin for several versions now:
http://www.stellarium.org/wiki/index.php/Telescope_Control_plug-in
UrsaMinor does more if you have an autoguider of course, I was just looking for something quick and dirty using hardware I already had available for tonight. ;-)
aaronpriest
Likes: 4 posts
by aaronpriest » Sat Mar 09, 2013 9:42 pm
BTW, that test program on the UrsaMinor page worked fine with my Panogear on COM4. Unfortunately telescope control is purposely disabled in their demo and there's no way to buy it online without contacting dealers that are not located in my country. No way I'd have something working by tonight with them. Haha
by fma38 » Sun Mar 10, 2013 8:04 pm
Stellarium can natively drive a Panogear with the GOTO hand controller... Without it, it needs a little server. The protocole is described here:
https://stellarium.svn.sourceforge.net/svnroot/stellarium/trunk/telescope_server/stellarium_telescope_protocol.txt
by fma38 » Tue Mar 12, 2013 11:24 am
Here is a python script which act as stellarium server to drive the Panogear head. I only tested it through the EthernetDriver, using the simulator which comes with Papywizard. Let me know if it works.
Note: I used the serial drive, so you first need to pair with the bluetooth module from the system, then give the correct virtual serial port at the top of the script (you can use Windows syntax on that OS: COM1, COM4...), and launch it. Then, connect from Stellarium (I used the port 9999).
# -*- coding: utf-8 -*-
""" v0.1
import struct
import SocketServer
import threading
import socket
import serial
# Stellarium server params
HOST, PORT = "localhost", 9999
PACKET_SIZE = 20
# Merlin/Orion params
ENCODER_ZERO = 0x800000
# Driver params
SERIAL_PORT = "/dev/ttyS0"
SERIAL_BAUDRATE = 9600
class AbstractDriver(object):
    """ Base (abstract) class for bus drivers.
    def __init__(self):
        """ Init the driver.
        self._lock = threading.RLock()
    def init(self):
        """ Init the connection.
        raise NotImplementedError("AbstractDriver.init() must be overidden")
    def shutdown(self):
        """ Shutdown the connection.
        raise NotImplementedError("AbstractDriver.shutdown() must be overidden")
    def acquireBus(self):
        """ Acquire and lock the bus.
        #print "AbstractDriver.acquireBus()"
        self._lock.acquire()
    def releaseBus(self):
        """ Unlock and release the bus.
        #print "AbstractDriver.releaseBus()"
        self._lock.release()
    def setTimeout(self, timeout):
        """ Set the timeout delay.
        @param timeout: timeout delay, in s
        @type timeout: float
        raise NotImplementedError("AbstractDriver.setTimeout() must be overloaded")
    def empty(self):
        """ Empty buffer.
        raise NotImplementedError("AbstractDriver.empty() must be overloaded")
    def write(self, data):
        """ Write data.
        @param data: data to write
        @type data: str
        @return: size of data written
        @rtype: int
        raise NotImplementedError("AbstractDriver.write() must be overloaded")
    def read(self, size):
        """ Read data.
        @param size: size of the data to read
        @type size: int
        @return: read data
        @rtype: str
        raise NotImplementedError("AbstractDriver.read() must be overloaded")
class SerialDriver(AbstractDriver):
    """ Driver for serial connection.
    def init(self):
        try:
            self._serial = serial.Serial(port=SERIAL_PORT, baudrate=SERIAL_BAUDRATE, timeout=3)
            self.empty()
        except:
            print "SerialDriver._init()"
            raise
    def shutdown(self):
        self._serial.close()
    def setRTS(self, level):
        """ Set RTS signal to specified level.
        @param level: level to set to RTS signal
        @type level: int
        self._serial.setRTS(level)
    def setDTR(self, level):
        """ Set DTR signal to specified level.
        @param level: level to set to DTR signal
        @type level: int
        self._serial.setDTR(level)
        self._serial.timeout = timeout
    def empty(self):
        if hasattr(self._serial, "inWaiting"):
            self.read(self._serial.inWaiting())
        #print "SerialDriver.write(): data=%s" % repr(data)
        size = self._serial.write(data)
        return size
        data = self._serial.read(size)
        #print "SerialDriver.read(): data=%s" % repr(data)
        if size and not data:
            raise IOError("Timeout while reading on serial bus (size=%d, data=%s)" % (size, repr(data)))
        else:
            return data
class EthernetDriver(AbstractDriver):
    """ Driver for TCP ethernet connection.
    def init(self):
        print "EthernetDriver._init(): trying to connect to %s:%d..." % ("localhost", 7165)
        try:
            #import time
            #time.sleep(3)
            self._sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
            self._sock.connect(("localhost", 7165))
            self._sock.settimeout(3)
            self.empty()
        except Exception, msg:
            print "EthernetDriver.init()"
            raise Exception(msg)
        else:
            print "EthernetDriver._init(): successfully connected to %s:%d" % ("localhost", 7165)
    def shutdown(self):
        self._sock.close()
        self._sock.settimeout(timeout)
    def empty(self):
        pass
        #Logger().debug("EthernetDriver.write(): data=%s" % repr(data))
        try:
            size = self._sock.send(data)
            #if size != len(data) + 2:
                #raise IOError("Failed to send data on ethernet")
            #else:
                #return size
            return size
        except socket.timeout:
            raise IOError("Timeout while writing on ethernet")
        except socket.error, msg:
            raise IOError(msg)
        try:
            data = self._sock.recv(size)
            #print "EthernetDriver.read(): data=%s" % repr(data)
            if not data:
                raise IOError("Connection lost")
            else:
                return data
            raise IOError("Timeout while reading on ethernet bus")
            raise IOError(msg)
class MerlinOrionHardware(object):
    """ Merlin/Orion low-level hardware.
    def __init__(self, axis, driver):
        self._axis = axis
        self._driver = driver
        self._encoderFullCircle = None
    def _decodeAxisValue(self, strValue):
        """ Decode value from axis.
        Values (position, speed...) returned by axis are
        32bits-encoded strings, low byte first.
        @param strValue: value returned by axis
        @type strValue: str
        @return: value
        @rtype: int
        value = 0
        for i in xrange(3):
            value += eval("0x%s" % strValue[i*2:i*2+2]) * 2 ** (i * 8)
        return value
    def _encodeAxisValue(self, value):
        """ Encode value for axis.
        Values (position, speed...) to send to axis must be
        @param value: value
        @type value: int
        @return: value to send to axis
        @rtype: str
        strHexValue = "000000%s" % hex(value)[2:]
        strValue = strHexValue[-2:] + strHexValue[-4:-2] + strHexValue[-6:-4]
        return strValue.upper()
    def _encoderToAngle(self, codPos):
        """ Convert encoder value to degres.
        @param codPos: encoder position
        @type codPos: int
        @return: position, in °
        @rtype: float
        return (codPos - ENCODER_ZERO) * 360. / self._encoderFullCircle
    def _angleToEncoder(self, pos):
        """ Convert degres to encoder value.
        @param pos: position, in °
        @type pos: float
        @return: encoder position
        @rtype: int
        return int(pos * self._encoderFullCircle / 360. + ENCODER_ZERO)
    def _sendCmd(self, cmd, param=""):
        """ Send a command to the axis.
        @param cmd: command to send
        @type cmd: str
        @return: answer
        @rtype: str
        cmd = ":%s%d%s\r" % (cmd, self._axis, param)
        #print "MerlinOrionHardware._sendCmd(): axis %d cmd=%s" % (self._axis, repr(cmd))
        for nbTry in xrange(3):
            try:
                answer = ""
                self._driver.empty()
                self._driver.write(cmd)
                c = ''
                while c not in ('=', '!'):
                    c = self._driver.read(1)
                    #print "MerlinOrionHardware._sendCmd(): c=%s" % repr(c)
                if c == '!':
                    c = self._driver.read(1) # Get error code
                    raise IOError("Error in command %s (err=%s)" % (repr(cmd), c))
                answer = ""
                while True:
                    if c == '\r':
                        break
                    answer += c
            except IOError:
                print "MerlinOrionHardware._sendCmd(): axis %d can't sent command %s. Retrying..." % (self._axis, repr(cmd))
            else:
                break
        else:
            raise Exception("axis %d can't send command %s" % (self._axis, repr(cmd)))
        #print "MerlinOrionHardware._sendCmd(): axis %d ans=%s" % (self._axis, repr(answer))
        return answer
    def init(self):
        """ Init the MerlinOrion hardware.
        Done only once per axis.
        self._driver.acquireBus()
        try:
            # Stop motor
            self._sendCmd("L")
            # Check motor?
            self._sendCmd("F")
            # Get firmeware version
            value = self._sendCmd("e")
            print "MerlinOrionHardware.init(): firmeware version=%s" % value
            # Get encoder full circle
            value = self._sendCmd("a")
            self._encoderFullCircle = self._encoderFullCircle_ = self._decodeAxisValue(value)
            print "MerlinOrionHardware.init(): encoder full circle=%s" % hex(self._encoderFullCircle)
            # Get sidereal rate
            value = self._sendCmd("D")
            print "MerlinOrionHardware.init(): sidereal rate=%s" % hex(self._decodeAxisValue(value))
        finally:
            self._driver.releaseBus()
    def overwriteEncoderFullCircle(self, encoderFullCircle):
        """ Overwrite firmware value.
        print "MerlinOrionHardware.overwriteEncoderFullCircle(): encoderFullCircle=%x" % encoderFullCircle
        self._encoderFullCircle = encoderFullCircle
    def useFirmwareEncoderFullCircle(self):
        """ Use value from firmware.
        print "MerlinOrionHardware.useFirmwareEncoderFullCircle(): encoderFullCircle=%x" % self._encoderFullCircle
    def read(self):
        """ Read the axis position.
        @return: axis position, in °
        @rtype: float
        try:
            value = self._sendCmd("j")
        finally:
        pos = self._encoderToAngle(self._decodeAxisValue(value))
        return pos
    def drive(self, pos):
        """ Drive the axis.
        @param pos: position to reach, in °
        @type pos: float
        strValue = self._encodeAxisValue(self._angleToEncoder(pos))
        try:
            self._sendCmd("L")
            self._sendCmd("G", "00")
            self._sendCmd("S", strValue)
            self._sendCmd("J")
        finally:
    def stop(self):
        """ Stop the axis.
        try:
            self._sendCmd("L")
        finally:
    def startJog(self, dir_, speed):
        """ Start the axis.
        @param dir_: direction ('+', '-')
        @type dir_: str
        @param speed: speed
        @type speed: int
        try:
            self._sendCmd("L")
            if dir_ == '+':
                self._sendCmd("G", "30")
            elif dir_ == '-':
                self._sendCmd("G", "31")
            else:
                raise ValueError("Axis %d dir. must be in ('+', '-')" % self._axis)
            self._sendCmd("I", self._encodeAxisValue(speed))
            self._sendCmd("J")
        finally:
    def getStatus(self):
        """ Get axis status.
        @return: axis status
        @rtype: str
        try:
            return self._sendCmd("f")
        finally:
    def setOutput(self, state):
        """ Set output state.
        @param state: new state of the the output
        @type state: bool
        try:
            self._sendCmd("O", str(int(state)))
        finally:
class IncomingPacket(object):
    """ Incoming packet from Stellarium.
    def __init__(self, message):
        """ Create the packet
        self.message = message
        length, type_, time_, ra, dec =  struct.unpack("<HHQIi", message)
        self.length = length
        self.type_ = type_
        self.time_ = time_
        self.ra = ra * 90. / 0x40000000
        self.dec = dec * 90. / 0x40000000
class MyTCPHandler(SocketServer.BaseRequestHandler):
    """ The RequestHandler class for our server.
    def handle(self):
        # self.request is the TCP socket connected to the client
        self.packet = IncomingPacket(self.request.recv(PACKET_SIZE).strip())
        print "MyTCPHandler.handle(): {} wrote:".format(self.client_address[0])
        print "MyTCPHandler.handle(): %s" % repr(self.packet.message)
        print "MyTCPHandler.handle(): time=%d, RA=%.2f, DEC=%.2f" % (self.packet.time_, self.packet.ra, self.packet.dec)
        yaw.drive(self.packet.dec)
        pitch.drive(self.packet.ra)
        while yaw.getStatus()[1] != '0' and pitch.getStatus()[1] != '0':
            time.sleep(0.1)
        print "MyTCPHandler.handle(): done"
        # just send back the same data
        #self.request.sendall(struct.pack("<HHQIii", length+4, type_, time_, ra+50000, dec-50000, 0))
class MyServer(SocketServer.TCPServer):
    allow_reuse_address = True
#driver = EthernetDriver()
driver = SerialDriver()
driver.init()
yaw = MerlinOrionHardware(1, driver)
yaw.init()
pitch = MerlinOrionHardware(2, driver)
pitch.init()
if __name__ == "__main__":
    # Create the server, binding to localhost on port 9999
    server = MyServer((HOST, PORT), MyTCPHandler)
    # Activate the server; this will keep running until you
    # interrupt the program with Ctrl-C
    server.serve_forever()
by fma38 » Tue Mar 12, 2013 2:37 pm
Here is a new version, with a few fixes:
""" v0.2
import struct
import SocketServer
import threading
import socket
import time
import serial
PACKET_SIZE = 20
# Driver params
    def __init__(self):
    def init(self):
    def shutdown(self):
    def empty(self):
        """ Empty buffer.
        """ Write data.
        @type data: str
        @rtype: int
        """ Read data.
        @type size: int
        @return: read data
        @rtype: str
    def init(self):
        try:
            self.empty()
        except:
            raise
    def shutdown(self):
        @type level: int
        @type level: int
    def empty(self):
        return size
        else:
            return data
    def init(self):
        try:
            #import time
            #time.sleep(3)
            self.empty()
        else:
    def shutdown(self):
        self._sock.close()
    def empty(self):
        pass
        try:
            #else:
                #return size
            return size
            raise IOError(msg)
        try:
            if not data:
            else:
                return data
            raise IOError(msg)
        self._axis = axis
        @type strValue: str
        @return: value
        @rtype: int
        value = 0
        for i in xrange(3):
        return value
        @param value: value
        @type value: int
        @rtype: str
        @type codPos: int
        @rtype: float
        @type pos: float
        @rtype: int
        @type cmd: str
        @return: answer
        @rtype: str
            try:
                answer = ""
                c = ''
                if c == '!':
                answer = ""
                while True:
                    if c == '\r':
                        break
                    answer += c
            except IOError:
            else:
                break
        else:
        return answer
    def init(self):
        try:
            # Stop motor
            self._sendCmd("L")
            # Check motor?
            self._sendCmd("F")
            # Get sidereal rate
        finally:
    def read(self):
        @rtype: float
        try:
        finally:
        return pos
        """ Drive the axis.
        @type pos: float
        try:
            self._sendCmd("L")
            self._sendCmd("J")
        finally:
    def stop(self):
        """ Stop the axis.
        try:
            self._sendCmd("L")
        finally:
        """ Start the axis.
        @type dir_: str
        @param speed: speed
        @type speed: int
        try:
            self._sendCmd("L")
            if dir_ == '+':
            elif dir_ == '-':
            else:
            self._sendCmd("J")
        finally:
        @rtype: str
        try:
        finally:
        @type state: bool
        try:
        finally:
        self.type_ = type_
        self.time_ = time_
    def handle(self):
        while True:
            print "MyTCPHandler.handle(): length=%d, time=%d, RA=%.2f, DEC=%.2f" % (self.packet.length, self.packet.time_, self.packet.ra, self.packet.dec)
            self.server.yaw.drive(self.packet.dec)
            self.server.pitch.drive(self.packet.ra)
            while self.server.yaw.getStatus()[1] != '0' and self.server.pitch.getStatus()[1] != '0':
                time.sleep(0.1)
            # just send back the reached position
            self.request.sendall(struct.pack("<HHQIii", self.packet.length+4, self.packet.type_, time.time(), self.packet.ra, self.packet.dec, 0))
def main():
    driver.init()
    server.yaw = MerlinOrionHardware(1, driver)
    server.yaw.init()
    server.pitch = MerlinOrionHardware(2, driver)
    server.pitch.init()
    main()
dim
by dim » Thu Apr 25, 2013 8:06 am
I have also a Panogear & Merlin (thank you!) on a Macbook with ubuntu 12.04... It works perfectly! And i read this very interresting topic. So i tried to use the Panogear & bluetooth with Stellarium 0.12.1.. When i launch the server, it make screen copy!
eos5Dc, eos5D2 + Magic Lantern 2.3 & nightbuild, canon 24-70mm f:2.8, sigma 180mm macro f:5.6, samyang 14mm f:2.8, helios-40 85mm f1.5, old yashica 800mm f8, manfrotto 302+ hackée, merlin + BTursaminor, macbook + ubuntu 12.04, osx, win7, intel quadcore + ubuntu 13.04 studio, win7, Darktable, GretagMcB eye-one, epson V750.
by fma38 » Thu Apr 25, 2013 8:13 am
!!!! Did you install a python interpreter?
Does anyone alse tried my script to drive a Merlin from Stellarium?
dim
by dim » Thu Apr 25, 2013 8:24 am
I think so! Python & libpython (2.7, 3.2, 3.3) are installed.
I don't know! I discover last night the possibility to drive Merlin with Stellarium!
by fma38 » Thu Apr 25, 2013 8:32 am
How do you start the server? Better try from a console...
dim
by dim » Thu Apr 25, 2013 8:47 am
In the console & the message: "line 4 $ v0.2 \n': command not found"
by fma38 » Thu Apr 25, 2013 9:32 am
I think you are trying to run the python script using the shell interpreter!!!
As I didn't put a shebang at the start of the file, you need to start it with:
$ python <script>
Or add this to the first line:
#!/usr/bin/python
and make the file executable, and launch it with:
$ ./<script>
dim
by dim » Thu Apr 25, 2013 9:46 am
Thanks for patience! I'm new with python and not a programmer. I will try it this night! I will tell you about it.
dimitri
by fma38 » Thu Apr 25, 2013 9:54 am
No problem. Thanks for your feedback.
Mateusz Malinowski
by Mateusz Malinowski » Thu Apr 25, 2013 5:28 pm
fma38 wrote:Does anyone alse tried my script to drive a Merlin from Stellarium?
Hi
am I doing something wrong?
1
- installed python 3.3.1 64bit http://www.python.org/ftp/python/3.3.1/python-3.3.1.amd64.msi
- create s.py with code http://www.kolor.com/forum/p112973-2013-03-12-15-37-56#p112973
- run "Python (command line)" - drag and drop s.py -> enter
- Syntax error: invalid syntax
2
- installed winpython http://code.google.com/p/winpython/downloads/detail?name=WinPython-64bit-3.3.0.0beta2.exe
- run "WinPython Interpreter.exe" - drag and drop s.py -> enter
dim
by dim » Thu Apr 25, 2013 6:03 pm
So! I can't find the correct virtual serial port used by bluetooth... I create one (sudo rfcomm connect rfcomm4 00:12:6F:21:AE:9B, mac address to find with hcitool scan), set it in the script & launch the server...It works! Launch Stellarium & connect to the Merlin... Connected. Send a star position... No problem.
Great! Good job! thanks a lot! Frédéric
dimitri
by fma38 » Thu Apr 25, 2013 9:54 pm
Good :)
Mateusz, try with python 2.x...
Mateusz Malinowski
by Mateusz Malinowski » Fri Apr 26, 2013 9:28 am
Same syntax error
(WinPython-64bit-2.7.3.3; python 64bit 2.7.4)
by fma38 » Fri Apr 26, 2013 9:45 am
Please, give the entire traceback...
Also try to run the script from IDLE, the python IDE.
- Right-click on the script, and choose 'Edit with IDLE'
- Run the script by pressing F5
Mateusz Malinowski
by Mateusz Malinowski » Fri Apr 26, 2013 3:19 pm
Done as you wrote. Now have
  File "C:\Users\MT\Desktop\s.py", line 12, in <module>
    import serial
ImportError: No module named serial
by fma38 » Fri Apr 26, 2013 3:28 pm
You need to install this module :
http://pyserial.sourceforge.net
Mateusz Malinowski
by Mateusz Malinowski » Fri Apr 26, 2013 3:54 pm
Sorry, it's hard to understand pythhon if never used it before. I'm not sure I succesfully installed it (http://pyserial.sourceforge.net/pyserial.html#installation)
  File "C:\Users\MT\Desktop\s.py", line 15, in <module>
    HOST, PORT = "localhost", COM7
NameError: name 'COM7' is not defined
by fma38 » Fri Apr 26, 2013 4:56 pm
HOST, PORT = "localhost", 9999  <<<<<<<<< do not change anything here...
PACKET_SIZE = 20
# Driver params
SERIAL_PORT = "/dev/ttyS0"  <<<<<<<<<<<<<< change your Merlin serial port here
