Nodal field in T&C panorama control
saeed_311
by saeed_311 » Tue Mar 13, 2012 9:45 am
I use canon 8-15 fisheye lens , What should I write in nodal in t&c panorama control?
by klausesser » Tue Mar 13, 2012 1:35 pm
saeed_311 wrote:I use canon 8-15 fisheye lens , What should I write in nodal in t&c panorama control?
There´s nothing to write into the T&C about the Nodal-point which would be vital. In the configuration program - when you store lenses and camera - you can put in the NPP-info. But that´s only a reminder for yourself.
You don´t need it. It´s not related to any calculations. I guess you know how to find the NPP for your combination?
To get informations about the position of the NPP at which focal-length you must contact Canon. The position changes with focal-setting and aperture.
I use a 15mm Canon fisheye - here it´s 4,5cm from the lense´s base to the front-lens @f8/11.
