The touch control panel incompatible with the Gigapan Wizard !!!
giorgio
by giorgio » Sun Feb 19, 2012 5:26 pm
Hello
After having photographed through the touch controller I found as follows.
The files are not ordered as requested by the Gigapan Import Wizard
The controller saves files with this order:
7 8 9
6 5 4
1 2 3
non-existent in the sense of taking (Gigapan import Module)
To give a consistent order, I rename the files.
Does anyone know tell me if there is a better solution or an alternative method?
Thank you very much
by gkaefer » Sun Feb 19, 2012 6:09 pm
giorgio wrote:Hello
7 8 9
6 5 4
1 2 3
Thank you very much
the T&C handcontroller (so the same device for the panogear) does write the logfile in papywizzard compatible xml files...
... so use the papywizard import modul instead for importing the log & images into autopano.
or did I miss something?
giorgio
by giorgio » Mon Feb 20, 2012 6:32 pm
Hi Georg,
Unfortunately using the form papywizard and xml file do not get results.
Just renaming the file, as mentioned above, giving a pre-established sequence from Gigapan
selecting the default layout to fix the problem!
Giorgio
by klausesser » Mon Feb 20, 2012 11:23 pm
giorgio wrote:Hi Georg,
Giorgio
Hi Giorgio!
As Georg said: The T&C writes a PapyWizard compatible xml. You can´t use it with the Gigapan module. They shoot in different orders.
Can you make screenshots from your import settings?
by mediavets » Tue Feb 21, 2012 12:15 am
giorgio wrote:Unfortunately using the form papywizard and xml file do not get results.
Giorgio
What camera and lens are you using?
Are you shooting a partial pano (a regular matrix grid of images) or a spherical pano with a variable number of images per row?
How many images are there in your image set?
In what way do you 'not get results'? Do you get error messages?
Which version of APP/APG are you using and with which operating systm?
giorgio
by giorgio » Tue Feb 21, 2012 11:11 pm
The photographic composition is: 60 frames (4 lines, 15 columns) with sequence
60....46
31....45
30....16
01....15
Papywizard plugin import with relative xml file ...
The preview is correct but the end result is a disaster!
Just renaming and reversing the sequence of line 30...16 and 60...46 and using the plugin and layout rows Gigapan upward to fix the problem:.
I also used the Module Bluetooth Deltawave PapyMerlin with excellent results.
Why in the Gigapan plugin does not exist a sequence as above being more logical?
Will perform other tests to understand where lies the flaw!
Thank to all
Giorgio
There are only two kinds of pc users: those who have lost data and those who will lose data
by mediavets » Tue Feb 21, 2012 11:26 pm
Giorgio,
I ask again - Which version of APP/APG are you using and with which operating systm?
giorgio
by giorgio » Wed Feb 22, 2012 12:45 am
Hi, Andrew,
T&C 2.4.0.0
APG 2.6.1
Windows 7
Giorgio
by klausesser » Wed Feb 22, 2012 1:11 pm
giorgio wrote:Why in the Gigapan plugin does not exist a sequence as above being more logical?
Again: you CAN`T USE the T&C-xml with the Gigapan-plugin. Use the PapyWizard-plugin.
Gigapan´s functions are different from the Merlin´s.
The T&C doesn´t work with the Gigapan-head.
So: use the PapyWizard-import - and careful check all the settings. They are a bit confusing.
That´s the reason i asked you to show some screenshots from your import-settings.
best, KLaus
by mediavets » Wed Feb 22, 2012 1:21 pm
giorgio wrote:Hi, Andrew,
T&C 2.4.0.0
APG 2.6.1
Windows 7
Giorgio
I think it would be worth trying APG 2.6.2 RC3 :
http://www.kolor.com/download-autopano-panotour-panorama-virtual-tour-software.html
When you say "the preview is correct but the end result is a disaster!" can you show us some screenshots?
I think you also reported that you have no problems with the Papywizard Import Wizard when shooting with Papywizard controlling the mount, you only have problems when using the T&C Touch controller to control the mount - is that correct?
giorgio
by giorgio » Thu Feb 23, 2012 4:50 pm
Example photo on one line only
01 Gigapan-plugin
02-03 PapyWizard-plugin
This is the xml file generated by touch controller
<?xml version="1.0" encoding="utf-8"?>
<papywizard version="a">
    <header>
        <general>
            <title>
                Session# 0
            </title>
            <gps>
                Here goes the location
            </gps>
            <comment>
                Generated by Panoramacontrol
            </comment>
        </general>
        <shooting mode="mosaik">
            <headOrientation>
                up
            </headOrientation>
            <cameraOrientation>
               portrait
            </cameraOrientation>
            <stabilizationDelay>
                0.5
            </stabilizationDelay>
            <startTime>
            </startTime>
            <endTime>
            </endTime>
        </shooting>
        <camera>
            <timeValue>
                1.0
            </timeValue>
            <bracketing intent="exposure" nbPicts="001"/>
            <sensor coef="X.X" ratio="X:X"/>
        </camera>
        <lens type="rectilinear">
            <focal>
                600.0            </focal>
        </lens>
        <mosaic>
            <nbPicts pitch="001" yaw="021"/>
            <overlap minimum="0.20" pitch="0.20" yaw="0.20"/>
        </mosaic>
    </header>
    <shoot>
        <pict bracket="001" id="0001">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+007.0"/>
        </pict>
        <pict bracket="001" id="0002">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+006.0"/>
        </pict>
        <pict bracket="001" id="0003">
            <time>
            </time>
        </pict>
        <pict bracket="001" id="0004">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+005.0"/>
        </pict>
        <pict bracket="001" id="0005">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+004.0"/>
        </pict>
        <pict bracket="001" id="0006">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+003.0"/>
        </pict>
        <pict bracket="001" id="0007">
            <time>
            </time>
        </pict>
        <pict bracket="001" id="0008">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+002.0"/>
        </pict>
        <pict bracket="001" id="0009">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+001.0"/>
        </pict>
        <pict bracket="001" id="0010">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="+000.0"/>
        </pict>
        <pict bracket="001" id="0011">
            <time>
            </time>
        </pict>
        <pict bracket="001" id="0012">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-001.0"/>
        </pict>
        <pict bracket="001" id="0013">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-002.0"/>
        </pict>
        <pict bracket="001" id="0014">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-003.0"/>
        </pict>
        <pict bracket="001" id="0015">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-004.0"/>
        </pict>
        <pict bracket="001" id="0016">
            <time>
            </time>
        </pict>
        <pict bracket="001" id="0017">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-005.0"/>
        </pict>
        <pict bracket="001" id="0018">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-006.0"/>
        </pict>
        <pict bracket="001" id="0019">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-007.0"/>
        </pict>
        <pict bracket="001" id="0020">
            <time>
            </time>
        </pict>
        <pict bracket="001" id="0021">
            <time>
            </time>
            <position pitch="+000.0" roll="90.0" yaw="-008.0"/>
        </pict>
    </shoot>
</papywizard>
by klausesser » Thu Feb 23, 2012 5:25 pm
giorgio wrote:Example photo on one line only
01 Gigapan-plugin
In your xmkl i read "600mm" for focal-lenth. In APG i read "0" for focal-length. So this can´t work at all.
Besides: i still don´t understand why you mention the Gigapan plugin . . . makes definitely no sense when
you use a Merlin and the T&C.
Type in 600mm focal length in the APG preferences. Close APG and start it again for making the prefs take it.
I guess it´s a BAD bug that the import-module doesn´t read the focal-length written in the xml.
This whole import-thing is a mess unless you work through it by try and error and find what you need.
besides that i strongly suggest to use always the latest version of APG!
by mediavets » Thu Feb 23, 2012 11:58 pm
Giorgio,
There's something weird here.
Your images seem to lack EXIF data - why is that? Is because youy have processed the images using the dehazing feature?
I've asked before and will ask again - what camera body and lens are you using?
Why does the XML file lack data for the sensor coeff and ratio?
giorgio
by giorgio » Fri Feb 24, 2012 12:20 am
Old 60-300 Tamron Lens with focal Doubler on Nikon D5000
Shooting in manual mode
Exif data not recordable
I therefore think that with this lens I use only Gigapan-plugin!
Giorgio
by klausesser » Fri Feb 24, 2012 1:27 am
giorgio wrote:I therefore think that with this lens I use only Gigapan-plugin!
Giorgio: that´s really weird . . :cool:
You must type in the focal-length as well as the sensor-size. Then you shouldn´t have a problem. I also use lenses without exif-numbers. I set it manually.
I wrote that before. Simply try it! ;)
by mediavets » Fri Feb 24, 2012 1:56 am
giorgio wrote:Hi,
Giorgio
OK - then edit the XML to correct the sensor data as follows:
<sensor coef="1.5" ratio="3:2"/>
giorgio
by giorgio » Fri Feb 24, 2012 11:57 am
Thanks to all
Giorgio
by mediavets » Fri Feb 24, 2012 1:02 pm
giorgio wrote:Thanks to all
Giorgio
Do you have the Papywizard Import working now with the Touch controller XML with the edits proposed?
giorgio
by giorgio » Sat Feb 25, 2012 12:49 am
After I changed the xml file with the final plugin Papywizard result does not change.
I think with this lens I use the Gigapan plugin without using Papywizard Import Wizard
Now I will use a Sigma 120-400, you will see the results !
Giorgio
Apapane
by Apapane » Sun Feb 26, 2012 5:48 pm
Georgio,
I use BOTH Panogear and GigaPan robotic camera mounts.
Whenever I use the Panogear mount, I use the Papywizard import plugin. The Panogear mount, when using the Touch Control, and grid pattern, takes images from left to right, THEN right to left, alternating direction until the panorama is complete.
The GigaPan mount can take images in rows Bottom to Top, rows Top to Bottom, columns L to R, and columns R to L. In all cases, each row or column is taken In The Same Sequence, ie - all rows are taken from L to R, and all columns from Top to Bottom. The GigaPan import plugin can't interpret the .xml files taken by the Panogear mount, thus, you must use the Papywizard import plugin.
In the same manner, the Papywizard import plugin can't properly align image grids taken with a GigaPan mount, since these images do not contain the information necessary for the Papywizard import plugin to process.
I can't comment about using the full capabilities of the Papywizard program, which, as far as I can tell, must use blue tooth to communicate from a computing device to the Panogear mount. I have yet to embark upon this journey, although it will be soon.
I hope I didn't make things more complicated than they should be!! ;^)
Best,
Richard
by mediavets » Sun Feb 26, 2012 6:07 pm
Apapane wrote:I can't comment about using the full capabilities of the Papywizard program, which, as far as I can tell, must use blue tooth to communicate from a computing device to the Panogear mount.
Papywizard can connect to the Merlin mount via a Bluetooth wireless connection on all supported platforms; or via a wired serial connection on all platforms except the Nokia Internet Tablets.
the Bluetooth option is the easiest ti implement as suitable adpaters are readily available.
There is no off-the-shelf RS232-TTL, or USB-TTL, adapter cable for the wired serial connection option.
