Problem running Papywizard Mosiac or Preset sequences
erinparker2020
by erinparker2020 » Mon Jan 16, 2012 11:27 pm
New user. We just got everything up and running this weekend. All was going well until this afternoon. Papywizard will no longer run sequences for Mosaic or Preset profiles. I can still control the pitch and yaw of the head with the directional arrows, but when I try to run a preset or mosaic sequence, nothing happens. In the dialog window that pops up after clicking on "Shoot" in the main window, The status says "active", the start button is lighted, but when clicked on, nothing happens.
The only thing we were doing when it quit working was changing the timer configuration settings (turning them on). We had also stopped a preset mid-shoot. We were shooting a 2 second exposure and the head was moving to the next position before the shutter had closed. So in the midst of trying to change time intervals something fouled up. I don't know whether it is related or if it was coincidence.
I can trigger the shutter under the "Hardware" drop-down. So the papywizard is communicating in some fashion, but not completely.
There appears to be an error in the log file, it says "Axis 1 can't sent command".
Hopefully a screencap of the log file appears below
by fma38 » Tue Jan 17, 2012 7:38 am
The log is missing. You can copy/paste all the log from the Help -> View log menu.
erinparker2020
by erinparker2020 » Tue Jan 17, 2012 6:55 pm
HEre is a copy of the log:
2012-01-16 20:10:55,047::Main::DEBUG::ConfigController.__onTimerAfterEnableCheckBoxToggled(): checked=False
2012-01-16 20:10:56,935::Main::DEBUG::Configuration saved
2012-01-16 20:11:14,711::Main::DEBUG::TotalFovController._onAccepted(): total fov set to yaw=100.0, pitch=96.7
2012-01-16 20:11:29,585::Main::INFO::Show shooting counter
2012-01-16 20:11:43,324::Main::DEBUG::ConfigController.__onCameraOrientationComboBoxCurrentIndexChanged(): orientation=portrait
2012-01-16 20:11:43,324::Main::DEBUG::ConfigController.__onLensTypeComboBoxCurrentIndexChanged(): type=rectilinear
2012-01-16 20:11:43,325::Main::DEBUG::ConfigController.__onLensTypeComboBoxCurrentIndexChanged(): lens type set to 'rectilinear'
2012-01-16 20:11:43,326::Main::DEBUG::ConfigController.__onShowShootingCounterCheckBoxToggled(): checked=True
2012-01-16 20:12:02,783::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Low limit' field
2012-01-16 20:12:02,783::Main::DEBUG::AbstractPluginController._initWidgets(): added 'High limit' field
2012-01-16 20:12:02,784::Main::DEBUG::AbstractPluginController._initWidgets(): created 'Hard' tab
2012-01-16 20:12:02,785::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Alternate drive' field
2012-01-16 20:12:02,785::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Alternate drive angle' field
2012-01-16 20:12:02,785::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Inertia angle' field
2012-01-16 20:12:15,174::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Low limit' field
2012-01-16 20:12:15,174::Main::DEBUG::AbstractPluginController._initWidgets(): added 'High limit' field
2012-01-16 20:12:15,175::Main::DEBUG::AbstractPluginController._initWidgets(): created 'Hard' tab
2012-01-16 20:12:15,176::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Alternate drive' field
2012-01-16 20:12:15,176::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Alternate drive angle' field
2012-01-16 20:12:15,176::Main::DEBUG::AbstractPluginController._initWidgets(): added 'Inertia angle' field
2012-01-16 20:12:25,696::Main::DEBUG::Configuration saved
erinparker2020
by erinparker2020 » Tue Jan 17, 2012 6:58 pm
The Warning Line of code below is what I think the problem is:
2012-01-16 20:09:50,643::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2012-01-16 20:09:50,644::Main::INFO::Starting connection. Please wait...
2012-01-16 20:09:50,645::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2012-01-16 20:09:52,479::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2012-01-16 20:09:54,209::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
File "papywizard/hardware/merlinOrionHardware.pyc", line 145, in __sendCmd
File "papywizard/driver/serialDriver.pyc", line 115, in read
IOError: Timeout while reading on serial bus (size=1, data='')
2012-01-16 20:09:54,210::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2012-01-16 20:09:54,302::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020781
2012-01-16 20:09:54,345::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-01-16 20:09:54,385::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-01-16 20:09:54,386::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2012-01-16 20:09:54,387::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2012-01-16 20:09:54,492::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020781
2012-01-16 20:09:54,533::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-01-16 20:09:54,575::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-01-16 20:09:54,576::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2012-01-16 20:09:54,577::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2012-01-16 20:09:54,675::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020781
2012-01-16 20:09:54,716::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-01-16 20:09:54,757::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-01-16 20:09:54,759::Main::INFO::Connection started
2012-01-16 20:09:54,839::Spy::INFO::Spy resumed
by fma38 » Tue Jan 17, 2012 10:02 pm
But what happens in the log when trying to shoot?
erinparker2020
by erinparker2020 » Thu Jan 26, 2012 4:54 am
I have cleared the log and just turned on Papywizard and tried to run a preset. When I click on shoot it shows the areas it should be shooting with the yellow circle. The device does not center itself. It will not respond in mosaic mode. I can manually control the head with the arrows. I have pasted the code below.
Erin
2012-01-25 21:38:50,955::Main::INFO::Starting Papywizard...
2012-01-25 21:38:50,955::Main::DEBUG::main(): platform=darwin
2012-01-25 21:38:51,611::Main::INFO::Importing modules...
2012-01-25 21:38:52,508::Main::INFO::Loading i18n files...
2012-01-25 21:38:52,514::Main::DEBUG::main(): locale=en_US
2012-01-25 21:38:52,515::Main::WARNING::Can't find qt translation file
2012-01-25 21:38:52,515::Main::INFO::Loading Style Sheets...
2012-01-25 21:38:52,521::Main::WARNING::No user Style Sheet found
2012-01-25 21:38:52,521::Main::INFO::Loading configuration...
2012-01-25 21:38:52,523::Main::DEBUG::ConfigManager.__init__(): versions: dist=['2', '1', '20'], user=[u'2', u'1', u'20']
2012-01-25 21:38:52,523::Main::DEBUG::ConfigManager.__init__(): user config. is up-to-date
2012-01-25 21:38:52,524::Main::INFO::Load plugins...
2012-01-25 21:38:52,527::Main::DEBUG::DslrRemoteProShutter._defineConfig()
2012-01-25 21:38:52,527::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,528::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb12@1/3', 'OUTPUT_DIR': '/Users/Erin', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\DSLR Remote Pro\\DSLRRemoteTest\\DSLRRemoteTest.exe'}
2012-01-25 21:38:52,528::Main::DEBUG::PluginsManager.register(): added 'DSLR Remote Pro' plugin with capacity 'shutter'
2012-01-25 21:38:52,529::Main::TRACE::EOSUtilityShutter._defineConfig()
2012-01-25 21:38:52,529::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,529::Main::DEBUG::AbstractPlugin._loadConfig(): config={'FOCUS_DIRECTION': u'far', 'BRACKETING_TYPE': '0-+', 'BULB_ENABLE': False, 'DRY_RUN': True, 'BULB_BASE_EXPOSURE': 1, 'FOCUS_NB_PICTS': 1, 'BRACKETING_NB_PICTS': 1, 'FOCUS_STEP_COUNT': 1, 'FOCUS_ENABLE': False, 'EOS_UTILITY_VERSION': u'new', 'PROGRAM_PATH': 'C:\\Program Files\\Papywizard\\EOSBracket.exe', 'BRACKETING_STEP': '1', 'FOCUS_STEP': u'medium'}
2012-01-25 21:38:52,529::Main::DEBUG::PluginsManager.register(): added 'EOS Utility' plugin with capacity 'shutter'
2012-01-25 21:38:52,530::Main::TRACE::GenericTetheredShutter._defineConfig()
2012-01-25 21:38:52,530::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,531::Main::DEBUG::AbstractPlugin._loadConfig(): config={'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False, 'PARAM_4': '', 'PARAM_1': '', 'PARAM_0': '', 'SHOOT_COMMAND': 'gphoto2 --capture-image', 'PARAM_2': '', 'TIME_VALUE': 0.10000000000000001, 'PARAM_3': ''}
2012-01-25 21:38:52,531::Main::DEBUG::PluginsManager.register(): added 'Generic Tethered' plugin with capacity 'shutter'
2012-01-25 21:38:52,533::Main::TRACE::GigaPanBotAxis._init()
2012-01-25 21:38:52,533::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,534::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,534::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0}
2012-01-25 21:38:52,534::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'yawAxis'
2012-01-25 21:38:52,534::Main::TRACE::GigaPanBotAxis._init()
2012-01-25 21:38:52,535::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,535::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,535::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0}
2012-01-25 21:38:52,535::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'pitchAxis'
2012-01-25 21:38:52,535::Main::TRACE::GigaPanBotShutter._init()
2012-01-25 21:38:52,536::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,536::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,536::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,536::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,537::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,537::Main::DEBUG::PluginsManager.register(): added 'GigaPanBot' plugin with capacity 'shutter'
2012-01-25 21:38:52,538::Main::TRACE::GphotoBracketShutter._defineConfig()
2012-01-25 21:38:52,538::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,538::Main::DEBUG::AbstractPlugin._loadConfig(): config={'BRACKETING_EV_STEP': 1, 'BRACKETING_EV_LIST': '0', 'BRACKETING_PLUS_STEP': 1, 'MIRROR_LOCKUP_COMMAND': 'gphoto2 --capture-image', 'MIRROR_LOCKUP': False, 'DOWNLOAD_DIR': '/Users/Erin', 'BRACKETING_MINUS_STEP': 1, 'DOWNLOAD_ENABLE': False, 'BRACKETING_NB_PICTS': 1, 'BRACKETING_MINUS_NB_PICTS': 0, 'BRACKETING_EV_BIAS': 0, 'BRACKETING_ADVANCED': False, 'BRACKETING_PLUS_NB_PICTS': 0, 'DOWNLOAD_THEN_DELETE': False, 'PROGRAM_PATH': 'gphoto2', 'DOWNLOAD_AFTER': u'Each shot'}
2012-01-25 21:38:52,539::Main::DEBUG::PluginsManager.register(): added 'Gphoto Bracket' plugin with capacity 'shutter'
2012-01-25 21:38:52,540::Main::TRACE::MerlinOrionAxis._init()
2012-01-25 21:38:52,540::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,540::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,541::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': True}
2012-01-25 21:38:52,541::Main::TRACE::MerlinOrionAxis._init()
2012-01-25 21:38:52,541::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,541::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,542::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': True}
2012-01-25 21:38:52,542::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'yawAxis'
2012-01-25 21:38:52,542::Main::TRACE::MerlinOrionAxis._init()
2012-01-25 21:38:52,542::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,543::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,543::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': True}
2012-01-25 21:38:52,543::Main::TRACE::MerlinOrionAxis._init()
2012-01-25 21:38:52,544::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,544::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,544::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'ALTERNATE_DRIVE_ANGLE': 7.0, 'INERTIA_ANGLE': 1.0, 'DRIVER_TYPE': u'serial', 'LOW_LIMIT': -360.0, 'ALTERNATE_DRIVE': True}
2012-01-25 21:38:52,544::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'pitchAxis'
2012-01-25 21:38:52,545::Main::TRACE::MerlinOrionShutter._init()
2012-01-25 21:38:52,545::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,545::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,545::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,545::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,546::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'serial', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,546::Main::TRACE::MerlinOrionShutter._init()
2012-01-25 21:38:52,546::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,546::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,547::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,547::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,547::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': u'serial', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,547::Main::DEBUG::PluginsManager.register(): added 'Merlin-Orion' plugin with capacity 'shutter'
2012-01-25 21:38:52,548::Main::DEBUG::NkRemoteShutter._defineConfig()
2012-01-25 21:38:52,549::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,549::Main::DEBUG::AbstractPlugin._loadConfig(): config={'USER_EXPOSURE_COMPENSATION_LIST': '-2, 0, +2', 'DRY_RUN': False, 'MIRROR_LOCKUP': False, 'FILENAME_PREFIX': '', 'CAMERA_EXPOSURE_COMPENSATION_LIST': u'\xb15@1/2', 'OUTPUT_DIR': '/Users/Erin', 'PROGRAM_PATH': 'C:\\Program Files\\BreezeSys\\NKRemote\\NKRemoteLibTest.exe'}
2012-01-25 21:38:52,549::Main::DEBUG::PluginsManager.register(): added 'NK Remote' plugin with capacity 'shutter'
2012-01-25 21:38:52,550::Main::TRACE::PanoduinoAxis._init()
2012-01-25 21:38:52,551::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,551::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,551::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 1000, 'HIGH_LIMIT': 360.0, 'DIRECTION': u'forward', 'ANGLE_1MS': 315.0, 'ACCEL': 1, 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'ADDITIONAL_DELAY': 1.5, 'SPEED': 5, 'CHANNEL': 0}
2012-01-25 21:38:52,551::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'yawAxis'
2012-01-25 21:38:52,552::Main::TRACE::PanoduinoAxis._init()
2012-01-25 21:38:52,552::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,552::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,552::Main::DEBUG::AbstractPlugin._loadConfig(): config={'NEUTRAL_POSITION': 1500, 'HIGH_LIMIT': 360.0, 'DIRECTION': u'reverse', 'ANGLE_1MS': 330.0, 'ACCEL': 1, 'LOW_LIMIT': -360.0, 'DRIVER_TYPE': 'bluetooth', 'ADDITIONAL_DELAY': 1.5, 'SPEED': 5, 'CHANNEL': 1}
2012-01-25 21:38:52,553::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'pitchAxis'
2012-01-25 21:38:52,553::Main::TRACE::PanoduinoShutter._init()
2012-01-25 21:38:52,553::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,553::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,553::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,554::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,554::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'SHUTTER_ON': 2000, 'SHUTTER_OFF': 1000, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200, 'CHANNEL': 2}
2012-01-25 21:38:52,554::Main::DEBUG::PluginsManager.register(): added 'Panoduino' plugin with capacity 'shutter'
2012-01-25 21:38:52,555::Main::TRACE::PixOrbAxis._init()
2012-01-25 21:38:52,556::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,556::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,556::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2012-01-25 21:38:52,556::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'yawAxis'
2012-01-25 21:38:52,557::Main::TRACE::PixOrbAxis._init()
2012-01-25 21:38:52,557::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,557::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,557::Main::DEBUG::AbstractPlugin._loadConfig(): config={'AXIS_ACCURACY': 0.10000000000000001, 'HIGH_LIMIT': 360.0, 'DRIVER_TYPE': 'bluetooth', 'LOW_LIMIT': -360.0, 'SPEED_INDEX': 9, 'AXIS_WITH_BREAK': False}
2012-01-25 21:38:52,557::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'pitchAxis'
2012-01-25 21:38:52,558::Main::TRACE::PixOrbShutter._init()
2012-01-25 21:38:52,558::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,558::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,558::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,558::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,559::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,559::Main::DEBUG::PluginsManager.register(): added 'PixOrb' plugin with capacity 'shutter'
2012-01-25 21:38:52,560::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,560::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2012-01-25 21:38:52,560::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'yawAxis'
2012-01-25 21:38:52,561::Main::DEBUG::AbstractPlugin._loadConfig(): config={'HIGH_LIMIT': 360.0, 'SPEED': 30, 'LOW_LIMIT': -360.0}
2012-01-25 21:38:52,561::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'pitchAxis'
2012-01-25 21:38:52,561::Main::TRACE::AbstractShutterPlugin._defineConfig()
2012-01-25 21:38:52,561::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,562::Main::DEBUG::AbstractPlugin._loadConfig(): config={'TIME_VALUE': 0.5, 'BRACKETING_NB_PICTS': 1, 'MIRROR_LOCKUP': False}
2012-01-25 21:38:52,562::Main::DEBUG::PluginsManager.register(): added 'Simulation' plugin with capacity 'shutter'
2012-01-25 21:38:52,562::Main::TRACE::TimelordShutter._defineConfig()
2012-01-25 21:38:52,563::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,563::Main::DEBUG::AbstractPlugin._loadConfig(): config={'PROGRAM_PATH': 'C:\\Program Files\\OxfordEye\\Timelord\\Timelord.exe', 'LRD_FILE': 'C:\\Documents and Settings\\win2k\\My Documents\\timelord.lrd'}
2012-01-25 21:38:52,563::Main::DEBUG::PluginsManager.register(): added 'Timelord' plugin with capacity 'shutter'
2012-01-25 21:38:52,564::Main::TRACE::UrsaMinorBt2Shutter._init()
2012-01-25 21:38:52,564::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,564::Main::TRACE::UrsaMinorBt2Shutter._defineConfig()
2012-01-25 21:38:52,564::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,565::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,565::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,565::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'FOCUS_PULSE_WIDTH': 0.5, 'FOCUS_MAINTAIN': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'FOCUS_ENABLE': False, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,565::Main::TRACE::UrsaMinorBt2Shutter._init()
2012-01-25 21:38:52,566::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,566::Main::TRACE::UrsaMinorBt2Shutter._defineConfig()
2012-01-25 21:38:52,566::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,566::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,566::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,567::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'FOCUS_PULSE_WIDTH': 0.5, 'FOCUS_MAINTAIN': False, 'BRACKETING_NB_PICTS': 1, 'TIME_VALUE': 0.5, 'FOCUS_ENABLE': False, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,567::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor BT2' plugin with capacity 'shutter'
2012-01-25 21:38:52,568::Main::TRACE::UrsaMinorUsbShutter._init()
2012-01-25 21:38:52,568::Main::TRACE::ShutterPlugin._init()
2012-01-25 21:38:52,568::Main::TRACE::UrsaMinorUsbShutter._defineConfig()
2012-01-25 21:38:52,568::Main::TRACE::AbstractHardwarePlugin._defineConfig()
2012-01-25 21:38:52,569::Main::TRACE::ShutterPlugin._defineConfig()
2012-01-25 21:38:52,569::Main::TRACE::AbstractPlugin._loadConfig()
2012-01-25 21:38:52,569::Main::DEBUG::AbstractPlugin._loadConfig(): config={'DRIVER_TYPE': 'bluetooth', 'PULSE_WIDTH_LOW': 200, 'BULB_ENABLE': False, 'MIRROR_LOCKUP': False, 'TRIGGER_LINE_INVERTED': False, 'BRACKETING_NB_PICTS': 1, 'TRIGGER_LINE': 'RTS', 'TIME_VALUE': 0.5, 'PULSE_WIDTH_HIGH': 200}
2012-01-25 21:38:52,569::Main::DEBUG::PluginsManager.register(): added 'Ursa Minor USB' plugin with capacity 'shutter'
2012-01-25 21:38:52,570::Main::INFO::Loading user plugins...
2012-01-25 21:38:52,570::Main::DEBUG::PluginsManager.register(): parsing '/Users/Erin/.config/papywizard2/plugins' dir...
2012-01-25 21:38:52,570::Main::INFO::Activate plugins...
2012-01-25 21:38:52,570::Main::TRACE::MerlinOrionPlugin.activate()
2012-01-25 21:38:52,571::Main::TRACE::MerlinOrionPlugin.activate()
2012-01-25 21:38:52,571::Merlin-Orion_yawAxis::DEBUG::MerlinOrionAxis.run(): start thread
2012-01-25 21:38:52,572::Merlin-Orion_pitchAxis::DEBUG::MerlinOrionAxis.run(): start thread
2012-01-25 21:38:52,572::Main::INFO::Creating model...
2012-01-25 21:38:52,575::Main::INFO::Loading default presets
2012-01-25 21:38:52,584::Main::DEBUG::Preset.__init__(): loading name='4@0 + Z + N'
2012-01-25 21:38:52,584::Main::DEBUG::Preset.__init__(): loading name='3@-15 + Z'
2012-01-25 21:38:52,584::Main::DEBUG::Preset.__init__(): loading name='6@30 + 6@-15 + N'
2012-01-25 21:38:52,585::Main::DEBUG::Preset.__init__(): loading name='4@30 + 4@-30'
2012-01-25 21:38:52,585::Main::DEBUG::Preset.__init__(): loading name='6@30 + 6@-30'
2012-01-25 21:38:52,586::Main::DEBUG::Preset.__init__(): loading name='6@0 + Z + N'
2012-01-25 21:38:52,586::Main::DEBUG::Preset.__init__(): loading name='6@-10 + 1@+60'
2012-01-25 21:38:52,586::Main::DEBUG::Preset.__init__(): loading name='3 + 6 + 12 + 6 + 3 (28mm)'
2012-01-25 21:38:52,587::Main::DEBUG::Preset.__init__(): loading name='4 + 12 + 12 + 12 + 8 (32mm)'
2012-01-25 21:38:52,588::Main::INFO::Loading user presets
2012-01-25 21:38:52,588::Main::WARNING::No user presets found
2012-01-25 21:38:52,588::Main::INFO::Starting Spy...
2012-01-25 21:38:52,589::Main::INFO::Creating GUI...
2012-01-25 21:38:52,589::Spy::INFO::Starting Spy...
2012-01-25 21:38:52,590::Spy::INFO::Spy suspended
2012-01-25 21:38:52,659::Main::WARNING::MainController.__getFullScreenFlag(): fix fullScreenFlag property!!!
2012-01-25 21:38:57,656::Main::DEBUG::MainController.__onActionHardwareConnectToggled(True)
2012-01-25 21:38:57,656::Main::INFO::Starting connection. Please wait...
2012-01-25 21:38:57,658::Main::DEBUG::PluginsConnector.start(): 'yawAxis' establish connection
2012-01-25 21:39:05,437::Main::DEBUG::PluginsConnector.start(): 'yawAxis' init
2012-01-25 21:39:07,164::Main::EXCEPTION::MerlinOrionHardware.__sendCmd
2012-01-25 21:39:07,165::Main::WARNING::MerlinOrionHardware.__sendCmd(): axis 1 can't sent command ':L1\r'. Retrying...
2012-01-25 21:39:07,263::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020781
2012-01-25 21:39:07,299::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-01-25 21:39:07,342::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-01-25 21:39:07,343::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' establish connection
2012-01-25 21:39:07,343::Main::DEBUG::PluginsConnector.start(): 'pitchAxis' init
2012-01-25 21:39:07,448::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020781
2012-01-25 21:39:07,490::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-01-25 21:39:07,531::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-01-25 21:39:07,532::Main::DEBUG::PluginsConnector.start(): 'shutter' establish connection
2012-01-25 21:39:07,532::Main::DEBUG::PluginsConnector.start(): 'shutter' init
2012-01-25 21:39:07,642::Main::DEBUG::MerlinOrionHardware.init(): firmeware version=020781
2012-01-25 21:39:07,679::Main::DEBUG::MerlinOrionHardware.init(): encoder full circle=0xe62d3
2012-01-25 21:39:07,719::Main::DEBUG::MerlinOrionHardware.init(): sidereal rate=0x6f9
2012-01-25 21:39:07,721::Main::INFO::Connection started
2012-01-25 21:39:07,802::Spy::INFO::Spy resumed
2012-01-25 21:39:16,498::Main::DEBUG::MainController.__onTabWidgetCurrentChanged(): shooting mode set to 'preset'
2012-01-25 21:39:20,010::Main::DEBUG::PresetScan.generatePositions(): preset=<Preset name=3@-15 + Z>
2012-01-25 21:39:24,195::Main::INFO::Show shooting counter
by fma38 » Thu Jan 26, 2012 8:53 am
The last line shows this:
I think you have the same issue as here:
http://www.kolor.com/forum/t13671-ra-solu-pilotage-ok-mais-sca-nario-marche-pas
There is a problem under MacOS: the counter window does not show up. To fix that, just turn this feature off in the Configuration (last tab).
erinparker2020
by erinparker2020 » Thu Jan 26, 2012 5:21 pm
That solved the problem. Thank you so much. We were worried the panogear head would not work with the MacBook Pro. I cannot wait to take it out and use it.
