Is free manual movement possible?
christianlapp
by christianlapp » Thu Nov 03, 2011 4:03 am
Additionally to automatically shooting the panorama I want to take extra photos of certain areas and later merge them into the panorama.
To achieve this, the camera has to stay in place and I would move the head by hand. Is this possible - e.g. when the head is off, or does the motor block any movement then?
To make clear: I don't talk about moving the head via the software, but really hands on.
Looking forward to your responses, Chris
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Nov 03, 2011 7:10 am
christianlapp wrote:I would move the head by hand. Is this possible - e.g. when the head is off, or does the motor block any movement then?
You can do that without problem, just be sure head is off (with the red power switch) before trying to move it by hand :)
Vincèn
Blog: http://www.skivr.com
christianlapp
by christianlapp » Thu Nov 03, 2011 10:27 am
vincen wrote:just be sure camera is off (with the red power switch)
I assume you meant HEAD is off.
Thank's! This is good news for my project!
Chris
Last edited by christianlapp on Thu Nov 03, 2011 10:28 am, edited 1 time in total.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Nov 03, 2011 10:44 am
christianlapp wrote:I assume you meant HEAD is off.
oups right I meant head for sure :cool:
