Canon EOS 5D II issues
All Terrain
by All Terrain » Sun Jul 10, 2011 11:41 am
Hello all,
I have just received the Panogear motorised head and have ben struggling to make it work with my Canon EOS 5D II.
The head rotates into place once the start and end points have been identified. However, unless I release the shutter manually, the shoot always fails (with the supplied cable). THis kind of invalidates the reason for buying this motorised head...
Can anyone help me? I need to use the Panogear very soon but canot get it to function with my 5D.
Thanks.
by mediavets » Sun Jul 10, 2011 12:08 pm
Are you using Papywizard or the Touch controller?
Manual focus or autofocus?
All Terrain
by All Terrain » Mon Jul 11, 2011 1:07 am
I am indeed using Papywizard 2.0 on my Mac via the bluetooth dongle as I wanted to operate the head remotely.
Everything on the camera is set to manual (focus and exposure).
by klausesser » Mon Jul 11, 2011 1:32 am
All Terrain wrote:I am indeed using Papywizard 2.0 on my Mac via the bluetooth dongle as I wanted to operate the head remotely.
You´re aware of having to connect the camera release cable to the Merlin i guess . . . are you sure to use the correct polarity? You might use an adapter from the 2,5mm jack on Merlin to the 3,5mm jack of the remote release cable.
I run a 5D2 with the Merlin and PapyWizard using my MacBook Pro via USB, or a Nokia N800 using BT or the TC handcontroller using the remote control cable to release the camera. It´s a short piece with the Canon-jack on the one and a 3,5mm female on the other end. A short cable with 3,5mm male jacks on both sides gives me the correct length.
Works fine in all cases.
Using the MB via BT i use the Merlin´s 2,5mm Jack and an adapter from 2,5 to 3,5mm to match the short Canon-adapter cable´s 2,5mm famale jack.
by fma38 » Mon Jul 11, 2011 7:54 pm
Do not use the 2.0 release; try the dev release, instead...
