Autopano Pro 2.0.6 And Autopano Giga 2.0.6
by AlexandreJ » Thu Nov 05, 2009 6:13 pm
It's another fix release :
Autopano Pro / Giga 2.0.6 Changelog
* FIXED - Extremely slow issue in lens distortion : http://www.autopano.net/forum/t7538-app-2.0.5-win-xp-sp3-32bit-extreeeeeemly-slow
* FIXED - Crash when merging panorama in GPU mode : http://www.autopano.net/forum/t7466-apg-2.0.5-win7-x64
* FIXED - Panotools export of fisheye crop zone
* FIXED - TIFF/JPG detection difference : http://www.autopano.net/forum/t7461-strange-detection-problem-with-tiffs
* FIXED - CP out of area in CP editor : http://www.autopano.net/forum/t7086-control-pt-editor-manually-displayingpoints-out-out-of-selected-area
o Same as : http://www.autopano.net/forum/t6985-apg-2.0.3-gentoo-64-cpu-cp-editor-places-cps-not-on-any-image
o Same as : http://www.autopano.net/forum/t6320-apg-v2-xp-sp3-nogpu-control-points-editor-cp-badly-displayed
* FIXED - 16 cpu / 32 cpu mode could not be used
* FIXED - Local geometry analysis could generates CP outside image
* FIXED - Deadlock when using 'guess unlinked picture position' tool without any control point in the panorama
* FIXED - Some ugly font issues in Linux version
* IMPROVED - Multiband memory usage has been reduced
* IMPROVED - Papywizard : http://www.autopano.net/forum/t7567-apg-using-papywizard-xml-for-positioning
o Same as - Papywizard : http://www.autopano.net/forum/t7585-as-i-wrote-before
o The roll attribute is now used. If source images don't have any exif, then, the focal length of the xml script is used.
* IMPROVED - Speed in several algorithms.
Autopano Tour 1.0.6 Changelog
* NO CHANGE
Note : you have now access to all version through an unique URL :
http://download.autopano.net/history
On one page, all v2 versions for every plateform.
taf
by taf » Fri Nov 06, 2009 2:08 pm
Salut Alexandre...
Merci pour cette nouvelle version.
Pour le point FIXED - Some ugly font issues in Linux version, ca solutionne aussi le pb que j'avais remonté ici ? : http://www.autopano.net/forum/t7322-app-2.0.4-win-xp-32-police-floue
Je n'ai pas encore installé la 2.0.6... pas eu le temps...
by AlexandreJ » Fri Nov 06, 2009 3:31 pm
Non, c'est pas lié.
taf
by taf » Sat Nov 07, 2009 11:08 pm
V2.0.6 installée, les polices sont toujours pourries...
je suis le seul à  avoir ce pb ou quoi ?
c'est bizarre, c'est la seule application qui me fait cela...
by AlexandreJ » Mon Nov 09, 2009 9:44 am
As-tu un soft de remplacement du bureau ?
taf
by taf » Mon Nov 09, 2009 2:53 pm
non, pas de zigouigoui dans ce genre...
ah quoi que je me demande... puisque j'ai installé une version XP 'sweet' qui effectivement remplace les icones par ceux de vista (like)... mais je ne sais pas si cela change quoi que ce soit au niveau des polices, qui ont l'air totu a fait standard...
en fait, ce soir il faut que j'installe la version 64 bits sous seven, cela devrait être OK...
taf
by taf » Mon Nov 16, 2009 1:02 am
installation de la version 64bits sous seven, plus de pb de polices...
kharvatis
by kharvatis » Thu Nov 19, 2009 12:54 pm
Avast antivirus reports that the .6 version (x64/windows) has got a virus!
by AlexandreJ » Thu Nov 19, 2009 4:30 pm
Avast is well know to give false warning. The installer available through our website are safe.
Michael Ezra
by Michael Ezra » Tue Jan 05, 2010 4:35 am
Alexandre, Happy New Year!
I imagine your team is working hard on some beautiful surprises you guys always manage to prepare:)!
Are they coming soon?:) I can't wait:)!
DrSlony
by DrSlony » Tue Jan 05, 2010 10:14 pm
AVG is even worse, if anyone here is using AVG, I seriously advise you to reconsider. The best completely free antivirus is avira, google around for the url to the free version, it was hard to find last time I looked.
hankkarl
by hankkarl » Thu Jan 07, 2010 2:58 pm
Haven't gotten any false results from AVG, but I'm using the paid version.
by gkaefer » Fri Jan 15, 2010 12:33 am
ah ;-) since Jan.13 the english language Autopano Pro/Giga 2 PDF Doku is online.
doku:
http://www.autopano.net/wiki-en/action/view/Main_Page
download:
http://ftp.autopano.net/releases/wiki/autopano-2-manual-en.pdf
thanks a lot!
tonyd
by tonyd » Tue Mar 09, 2010 11:45 am
Hi
Does anyone know when 2.0.7 will be released and hopefully fix the crashing problems reported with 2.0.6? I have used the trial of this but am wary of buying software which seems to have gone downhill from stability of previous versions (based on forum comments).
Tony
[bo]
by [bo] » Tue Mar 09, 2010 12:41 pm
What kind of crashing problems? If you're talking about the Smartblend memory problems - that's not going to be solved in 2.0.x, but in 2.x. You can "solve" those by getting plenty of RAM or using Multiband.
tonyd
by tonyd » Wed Mar 10, 2010 12:17 am
'[bo wrote:']What kind of crashing problems? If you're talking about the Smartblend memory problems - that's not going to be solved in 2.0.x, but in 2.x. You can "solve" those by getting plenty of RAM or using Multiband.
It crashes on exit. I appreciate not a major issue, but equally not what I expect of software at this price. I read it happens and it does using the demo too (Vista Home Premium, P4 3gzHT, 2gb Ram and laptop with Centrino 1.7gz, 1.5gb ram - both identical).
Tony
by gkaefer » Wed Mar 10, 2010 12:55 am
Tony
did not see such a crash on my win vista prof 32 nor on win7 RC 64bit or win7prof64 and 32 bit version. crashes in general: my experience are crashes on 64bit win 7 only 5-10% of those I had with vista 32 bit....
Panorama fanatic
by Panorama fanatic » Fri Mar 12, 2010 12:12 am
To Alexandre:
some time ago you wrote me about registration for translators. I lost that message, but remembered now :) Can you remind me what to do (if your offer is actual now).
