Panotour / Panotour Pro 2.5.8
Likes: 60 posts
Liked in: 169 posts
by benji33 » Thu Jun 29, 2017 9:00 am
We are happy to publish today the 2.5.8 release of Panotour & Panotour Pro.
We added some cool features on Panotour. Here's a detailed list of the new features.
· krpano viewer 1.19pr10
This version of Panotour/Panotour Pro generates tours using the tenth pre-release of 1.19 version of krpano.
· Enter/exit the VR mode will keep the current scene
In previous Panotour Pro versions the current scene wasn't kept when entering or exiting the VR mode. This support has been added into this version.
· TrueType custom fonts support
The support of custom TTF (TrueType) fonts has been added into Panotour. Select the Edit > Open user directory menu item, create a fonts directory and add your custom TTF fonts into this new directory. All the custom fonts used in the project will be integrated during the build.
· Bing Maps V8 Web Control
As announced in June 2016, end of life for Bing Maps AJAX V7 Control (V7) and SOAP Web Services offerings will take place on June 30, 2017. So if your tours use the Bing Maps API, install this new Panotour upgrade and update your projects.
· Youku as Web Video Viewer plugin provider
We added Youku as video provider for the Web Video Viewer HTML5 plugin.
· Look to action now takes field of view into account
Previously the View Control > Look to action was not using the destination FOV parameter.
· Website Viewer plugin margins issues on mobile devices
The core script of the Website Viewer plugin has been patched to take into account the margins set when the tour is visualized on a mobile device.
· And other bug fixes, refer to the full changelog to learn about what was fixed.
Enjoy it!
Kolor Blog: http://www.kolor.com/2017/06/28/virtual ... pro-2-5-8/
Download: http://www.kolor.com/panotour/download/
Warning
Bing Maps V7 control and SOAP Web Services deprecation on June 30:
After June 30, support for the V7 control will end and service availability will no longer be guaranteed.
More informations here.
Features and fixes since 2.5.7:
- 0005890: [Algorithm] When a source file of a scene is not found during a build the scene is deleted from the project
- 0005894: [Algorithm] Changing the features of a control bar "elementlist" changes the feature of the other one
- 0005916: [Algorithm] Optimization: better checks on OpenGL
- 0005915: [Algorithm] Optimization: avoid racing of some threads
- 0005913: [Crash Dump] Better checks on database calls when closed
- 0005914: [Crash Dump] Better checks on the management of cube faces
- 0005905: [krpano] Upgrade to krpano 1.19pr10
- 0005897: [Plugin] Website box plugin: internal margin property is not taken into account on mobile devices
- 0005909: [Plugin] Web Video Viewer plugin: add Youku video provider
- 0005910: [Plugin] Panotourmaps plugin: support of Bing maps API v8
- 0005892: [Tour] "Look to" action does not take FOV into account
- 0005904: [Tour] The current scene isn't kept when entering/exiting VR mode
- 0004807: [UI] Add SVG image support into files inputs
- 0005891: [UI] Messages for parallax options in Presets are not the same that default spots
- 0005898: [UI] Allow tel: and sms: prefix in URL fields
- 0005906: [UI] Fix Kolor shop urls
- 0005911: [UI] Map Editor: support of Bing Maps API v8
- 0005918: [UI] TTF custom fonts support
Omni VR likes this post.
