GoPro VR Player 2.3 Beta 1
Likes: 86 posts
Liked in: 191 posts
by benji33 » Wed Mar 29, 2017 12:43 pm
Today we are happy to publish the first beta version of GoPro VR Player 2.3!
This new update brings a couple new features and some bug fixes.
What's new?
Menu Bar
A brand new menu bar with all sorts of useful options and settings has been added. The keyboard shortcuts are also visible in the menu bar.
Facebook 360 video as input
Many customers wanted the support of Facebook 360 3:2 cubemap videos in GoPro VR Player. This is possible with this new release.
Loop toggle
We've added a loop toggle to change the way a playlist or a file is looped. You can loop a playlist, a single file or deactivate the loop.
Add some momentum to direction change
With this new release, pan and keypress action add some momentum to direction change. This option can be deactivated into the General settings.
Extract a print of the viewport to best quality
A new print screen option is now available and called "Print Screen HQ".
With Ctrl+Alt+P or Cmd+Alt+P a snapshot of the viewport is registered in the highest quality. The snapshot size is linked to current pixel density of the view.
The file browser points to the latest opened folder
In this version, we decided to use by default the latest opened folder when selecting Open Media.
OpenVR SDK version 1.0.6
OpenVR is an API and runtime that allows access to VR hardware from multiple vendors without requiring that applications have specific knowledge of the hardware they are targeting.
Adobe Premiere Plugin Update
We have continued work on the plugin and added a way to restore the player once exited.
For more detailed information, click here: http://www.kolor.com/2017/03/29/360-vid ... -3-beta-1/
To download the new 2.3 Beta 1 release, click here: http://www.kolor.com/gopro-vr-player/download/#beta
