Panotour / Panotour Pro 2.0 RC 2
Likes: 14 posts
by bdd » Thu Jan 16, 2014 4:07 pm
We released today the second Release Candidate version of Panotour/Panotour Pro 2.0 .
We are very close to the final version.
Here is the list of the fixes done since the first RC version :
- 0001357: [UI] RTL texts badly displayed on windows - in the final tour and in some widgets in Panotour
- 0001923: [UI] Panotour is minimized during the build of the tour
- 0002376: [UI] With little properties width, actions with goto panorama display a preview highest than the container
- 0002542: [UI] Undo : seems generate project from scratch after undo task
- 0002883: [UI] Hotspot style with action : bad refresh into the Tour Workspace
- 0002965: [UI] Height and Width are swapped between "Point spot style" and "Map point style"
- 0002991: [UI] FTP : some JS files missing after the upload
- 0002993: [UI] Verify auto-update of items and linkage into UI
- 0002998: [UI] Description is overwritten after build.
- 0003015: [UI] LivePano : transparent dialog window
- 0003025: [UI] CRASH : Images selector for plugins : quick add/remove (+/-) crashes panotour
- 0003055: [UI] Color chooser : Alpha value resetted when the HTML hexa value is get or set
- 0001257: [Algorithm] Zoom constraints are lost when coming back from Little Planet
- 0001942: [Algorithm] PSD Cube faces are badly imported in PTP2.0, while they are correctly imported in PTP1.8
- 0002288: [Algorithm] FTP : all files are not uploaded with project specific filenames
- 0002957: [Algorithm] JSBootstrap/JSBootstrapLoaded templates are not "conditioned"
- 0002981: [Algorithm] Add conditional items in plug_info
- 0002982: [Algorithm] Export algorithm does not manage big gigapixels
- 0002983: [Algorithm] Do not add http:// in URL fiels when the field contains a single filename "xxx.html"
- 0002995: [Algorithm] CRASH : when modifying the default values of a spot style action while a spot using this style
- 0003009: [Algorithm] Exporting HTML5 only tour from cube faces panorama does not create the cube faces
- 0002332: [Tour] Tooltip : in HTML5 tooltip can be badly displayed if into an align bottom component
- 0002859: [Tour] Convert SWFPATH to FIRSTXML for HTML5 tour played into HTML5 player
- 0002961: [Tour] Display image from mapSpot and floorplan cause error if no file is set
- 0002986: [Tour] No more mono resolution on mobile/tablet
- 0003010: [Tour] Spot display video action doesn't work with IE10-11 on HTML5 player
- 0003012: [Tour] Spot sounds and launch sound action compatibilities/incompatibilities (flash+html5)
- 0003014: [Tour] Need to add jQuery libs into all templates even if non HTML5 plugin.
- 0003030: [Tour] Unable to call "Display Video" action on a floorplan hotspot
- 0003032: [Tour] Unable to display a Web Video Box on a floorplan spot
- 0003051: [Tour] sound played with play sound action is not stopped by "stop tour sound" action
- 0002533: [Plugin] Loader Information : hide it on html5 player and for multi-resolution
- 0002684: [Plugin] Classic control bar : change the alpha rules to provide full opacity with non transparent ressources
- 0002815: [Plugin] Gallery : add title (manually) is bugged
- 0002861: [Plugin] PanoramaMenu : conditionnal button effect
- 0002934: [Plugin] ProjectionMenu : verify all projections and resets
- 0002944: [Plugin] IE8 bugs on FloorPlan
- 0002963: [Plugin] PanoramaMenu : remove problem due to innerHtml injection for IE9 and lower
- 0002966: [Plugin] Description : remove the default specific title text and correct specified text refresh
- 0002967: [Plugin] PanoramaMenu : select a submenu item close the submenu on touch devices
- 0002978: [Plugin] FloorPlan bugged on ActivateSpot method
- 0002994: [Plugin] Thumbnails bar : orientation problem
- 0003003: [Plugin] FloorPlan : two differents radars can be selected on init
- 0003023: [Plugin] Thumbnails bar : display on onxmlcomplete event rather than on onloadcomplete event
- 0003024: [Plugin] FloorPlan : bottom map spots are display as centered ones
http://www.kolor.com/blog-en/2014/01/16/virtual-tour-software-panotour-panotour-pro-2-0-rc2/
Re: Panotour / Panotour Pro 2.0 RC 2
by benji33 » Fri Jan 17, 2014 5:19 pm
Panotour RC2 html template now use all the time the jQuery library.
If you're using your own html template files you'll have to update them with the add of these lines into the header <head> tag :
<!--[if !IE]><!-->
  <script type="text/javascript" src="GroupedFloorPlandata/lib/jquery-2.0.3.min.js"></script>
  <!--<![endif]-->
  <!--[if lte IE 8]>
  <script type="text/javascript" src="GroupedFloorPlandata/lib/jquery-1.10.2.min.js"></script>
  <![endif]-->
  <!--[if gt IE 8]>
  <![endif]-->
