Autopano 3.0.6
renan
Autopano 3.0.6
by renan » Thu Jul 04, 2013 3:57 pm
Main changes
Today, we are launching a new fix release for the latest issues reported by our users. It also contains some improvements.
GPU texture size
We added a new option in the general settings to be able to use a reduced texture size while editing a panorama. It betters the experience while using the GPU in the case it hasn't much RAM. Nowadays, cameras produce huge pictures and the GPUs don't always accept the full size because it requests a lot of GPU RAM. This option is here to help you work with GPU on smaller configurations.
Helpers in the mask tool
The mask tool is a great tool but some helpers were needed to be able to improve the usability. So we added several new menus to be able to erase quickly the quick mark, some contextual menu too, etc.
Fixes in several software parts
* With some large renderings ( gigapixels ) on smaller configurations, a crash during the rendering stage could occur. This issue has been solved with the help of a user who tested our fix before integrating it to this build. Thanks to him.
* In the VRDrive2 import plugin, the focal length calculation and distortion were not handled well. This has been fixed.
* Some fixes in the Clauss import plugin.
* Added Portuguese translation that was missing in the previous 3.0.5 version.
* Several crash dumps have been analyzed and ended in fixes in different software parts.
Trial mode changes
We released Autopano Video some time ago and it appears that to be able to try it well, Autopano Pro or Giga were needed to level the horizon. But Autopano Pro / Giga in trial mode don't allow to save the project file (.pano) so you couldn't level the horizon of a video if you just used Autopano Pro/Giga and Autopano Video both in trial mode.
We decided to change that so you can save the project file even in trial mode. This saving is limited in trial mode but the project file (.pano) can be read back in Autopano Video, so that you can produce a leveled but watermarked video by using both software applications in trial mode.
In trial mode, we also changed the way the watermarking is done, by adding the sign everywhere in the final rendering. It doesn't change anything as you can still use the software with full features in trial mode.
Roadmap
With the knowledge we now have after developing Autopano Video, we can use the GPU in a better way in Autopano Pro/Giga too.
So we are pretty confident to release a 3.0.7 version quite soon with an updated GPU engine that will work really faster than in previous versions.
In 3.0.7, we'll also cope with external software support, like Bridge CC support.
Download here : http://www.kolor.com/blog-en/2013/07/04/panorama-software-autopano-pro-giga-3-0-6/
If you need full changelog, it is on the blog or here : http://download.kolor.com/app/stable/history ( just a reminder )
HansKeesom
by HansKeesom » Thu Jul 04, 2013 8:47 pm
renan wrote:GPU texture size
Roadmap
By turning down GPU texture size to the lowest setting I am now able to work 6 instead of 2 panoramas at the same time while still using my 4 GB GPU. I only see advantages as the resulting pano in preview seems to be at same resolution. Loving it.
Very curious what 3.0.7. will add to this jump in performance.
Regards, Hans Keesom
astro12nata5
by astro12nata5 » Fri Jul 05, 2013 9:55 am
But still polish users don't see polish translatnions. Translation files are in the translation folder, but we don't see it in the menu window.
