Autopano Engine 2.5 RC 2
by AlexandreJ » Fri Jan 14, 2011 4:12 pm
I want to wish to everyone a really nice Year ( with a lot of images inside a lot of panorama ).
I should have done that a bit sooner, but I had my nose stucked in the code ( and in the turkey ;) )
I'm really happy to disclose this second Release Candidate.
We did some great fixes in this release. A lot of complicated bug were catched and a lot of stability has been gained.
URL for download and changelog :
http://www.autopano.net/forum/t10966-autopano-engine-v2.5-rc2-changelog
One note. We redesigned our version tracker and download system. Everything is unified for all products.
Stable version :
* http://download.kolor.com/app/stable/history
* http://download.kolor.com/apg/stable/history
* http://download.kolor.com/pt/stable/history (not working because no final release of Panotour std yet )
* http://download.kolor.com/ptp/stable/history (not working because no final release of Panotour std yet )
Beta version :
* http://download.kolor.com/app/beta/history
* http://download.kolor.com/apg/beta/history
* http://download.kolor.com/pt/beta/history
* http://download.kolor.com/ptp/beta/history
Take care,
Alexandre
Chemop
by Chemop » Fri Jan 14, 2011 6:22 pm
I downloaded Windows 32bit RC2 and found myself with a trial version, with a registration code on screen which is new to me, but which is not recognised when I input it on the register screen. Is this counted as a new version for purchase purposes? I purchased autopano 2 in April 2009 after using APP since 2006. If I need to update with a new registration, the update website and instructions are not clear to me and I am not sure what I have to do or what I have to pay (if any). Am I being unintelligent? Please advise. Regards Peter N.
by mediavets » Fri Jan 14, 2011 6:52 pm
Are you sure you didn't accidentally download Autopano Giga instead of Autopano Pro (or vice versa)?
Chemop
by Chemop » Fri Jan 14, 2011 7:17 pm
Thanks for the suggestion but it is definitely AutopanoPro_win32_250RC2_2011-01-14 downloaded a couple of hours ago. I actually had the same experience yesterday with RC1 but expected the new version to overcome the problem. Regards Peter N.
streameru
by streameru » Sat Jan 15, 2011 6:08 pm
I am having the similar problem as Chemop/Peter N. Downloaded AutopanoPro_Mac_Leopard_250RC2_2011-01-14.dmg, asking for a registration code. I do have a license for AutopanoPro for Mac..
Mike
by fma38 » Sat Jan 15, 2011 6:12 pm
Check if the version launched is really the one you expect; there where a packaging problem on the beta debian version (file: APG, program: APP); this can be the same issue here...
streameru
by streameru » Sat Jan 15, 2011 6:20 pm
Autopano Pro 64bits 2.5.0RC2 - Trial version...
screen shot be helpful?
Anything else I can send that would be helpful?
Thanks,
Mike
streameru
by streameru » Sat Jan 15, 2011 6:25 pm
CORRECTION...
re-downloaded the file, re-entered my registration info, and now it appears to work.
Thanks,
Mike
by klausesser » Sat Jan 15, 2011 7:55 pm
no problems here on Mac.
hankkarl
by hankkarl » Sun Jan 16, 2011 2:47 am
Win 7 64 bit is ok
Chemop
by Chemop » Mon Jan 17, 2011 11:01 am
I have tried again with AutopanoPro_win32_250RC2_2011-01-14 and still get a trial version and an invalid registration code. And I still cannot find the way to get my registration code updated. I am directed to www.kolor.com/buy/user but there is no help there for RC2, only 2.0 for which I am registered. Please advise. Regards Peter N.
by mediavets » Mon Jan 17, 2011 11:04 am
Chemop wrote:I have tried again with AutopanoPro_win32_250RC2_2011-01-14 and still get a trial version and an invalid registration code. And I still cannot find the way to get my registration code updated. I am directed to www.kolor.com/buy/user but there is no help there for RC2, only 2.0 for which I am registered. Please advise. Regards Peter N.
You don't need a new licence key for 2.5.
Chemop
by Chemop » Mon Jan 17, 2011 11:13 am
Thanks for that but I'm still getting the trial version and an invalid code even after a re download (which seemed to work for streameru above). Why is that? I still need help please. Regards Peter N.
by klausesser » Mon Jan 17, 2011 11:27 am
Chemop wrote:Thanks for that but I'm still getting the trial version and an invalid code even after a re download (which seemed to work for streameru above). Why is that? I still need help please. Regards Peter N.
delete the preferences in the pref. folder and type in the serial again.
by AlexandreJ » Mon Jan 17, 2011 1:20 pm
If you have lost your registration key or if you are not sure of it, you have a nice user account here : http://www.kolor.com/magento-support/ , login and you can get everything back easily.
Chemop
by Chemop » Mon Jan 17, 2011 2:45 pm
Thanks everybody. It is now working for me. Regards Peter N.
taf
by taf » Tue Jan 18, 2011 9:22 pm
merci pour la release...
yvano
by yvano » Mon Jan 24, 2011 2:20 pm
aprés avoir installé la version rc2 je rencontre toujours le même probléme avec des panos gigapixels (250 photos) : ça plante lors du rendu en psd avec calques intégrés...
Suis au bord de la dépression moi :(
D300 + NN3 + 10.5 fisheye + 17/55 + sigma 70/200
by AlexandreJ » Mon Jan 24, 2011 4:21 pm
Bonjour ypano.
Serait-il possible de faire un rapport complet en tant que message séparé avec des détails sur le panorama, le rendu demandé et la machine ?
Voici les guidelines pour cela : http://www.autopano.net/forum/t9202-readme-first
yvano
by yvano » Mon Jan 24, 2011 4:34 pm
Bonsoir,
ok je m'en occupes demain !
