Possibilte de slideshow avec les vues d'une visite virtuelle
Vous avez une bonne idée ou une demande de fonctionnalité ? Postez ici pour en discuter. Les concepts les plus demandées sont généralement mis en oeuvre, car Panotour est très axée sur la communauté.
fredciel
by fredciel » Sat Sep 24, 2011 5:22 pm
Bonjour
Je pense qu'il serait interessant d'avoir la possibilite de lancer un slide show qui permettrait de changer automatiquement de vue apres x secondes.
Une visite virtuelle deviendrait une animation que l'on pourrait laisser tourner plein ecran un peu comme une demo...
What do you think?
fredciel
by mediavets » Sat Sep 24, 2011 6:20 pm
This has been requested many times before.
Kolor has promised to address this issue at some future date.
Meanwhile if you need something now you could use this program which works with Flash VRs created using Pano2VR:
http://ww2.360panotours.com/
by gkaefer » Tue Dec 20, 2011 3:11 am
Im currently working on a new theme with some features extra...
... currently struggling (but good hope to succeed) with a slideshow feature...
see current features:
http://www.kolor.com/forum/p92164-2011-12-17-02-34-26#p92164
the slideshow (transition after x seconds to next pano) is ready...
... currently struggling with panotours option in GUI to choose free tourname (this affects the filenames used)
and also calculating the correct number of available slides...
additional I plan to include some generic movements, which can be choosen finally via general xml variable placed at top lines of the xml template...
so 180"/360" turns and zooms to specific points in pano can be realized before switch to next pano...
(currently I plan with end of January to be ready to go public... currently it has >2500 lines of code)
Liebe Gruesse,
(lol - tried twice - posted a single time, each time published twice... and delete of last post also deletes double posting....)
