default size of map-preview
Vous avez une bonne idée ou une demande de fonctionnalité ? Postez ici pour en discuter. Les concepts les plus demandées sont généralement mis en oeuvre, car Panotour est très axée sur la communauté.
by gkaefer » Mon Feb 21, 2011 2:13 pm
default sourcecde produced by PTP if you enable map is:
<plugin name="map" url="pano-data/map/map.jpg" keep="true" align="lefttop" x="10" y="10" width="23" height="40" handcursor="false" onloaded="action(hidemapspot);" onclick="action(openmap);"/>
if the map is in original size 258 * 439 pixel. So I assume your allgorythm says per default 10% or orig size place the default map on top left corner...
my screenshot shows the default map at 20%, I hardcoded xml to "width="46" height="80" and this is still very small, but now recognizable....
featurerequest: after uploading map image PTP can calculate the default 10% valuefor the map preview. It would be perfect than to have an option field showing these width and heights pixel values so you can adopt if desired... Or alternativley having a slider where you can change between 0-100% of original map size.
Liebe Gruesse,
