Filets noirs rectilignes apparaissant plus ou moins selon le zoom
Ce forum est entièrement consacré à Autopano Tour.<br />
eric_222
by eric_222 » Thu Aug 26, 2010 4:53 pm
Assemblage créé avec Autopano Giga, retravaillé avec Gimp, puis calculé dans APT1.1.0 beta 9. (JPG d'environ 100 Mo; 19468x9734)
-temps de création/enregistrement du pano long, plusieurs dizaines de secondes
(malgré la prise en compte des conseils mono coeur CPU cf: http://www.autopano.net/forum/t9528-temps-de-calcul-tra-s-long)
-des lignes noires très fines (droites) apparaissent lors de la visualisation du swf (plus ou moins visibles selon le zoom)
J'ai testé avec une autre version tiff et jpg du fichier image, le problème subsiste.
Merci par avance,
Eric_222
by mediavets » Thu Aug 26, 2010 5:45 pm
eric_222
by eric_222 » Thu Aug 26, 2010 6:21 pm
I didn't try this new beta ... Why aren't we informed when there is an new version ?
I buy my software in July 2010, and I don't understand why we have to use "beta" version to solve such problems.
I loose a lot of time to find solution in forums.(no information offline with the software !)
Is this new beta a french version ? What about "preferences" for using one or multi core with this new version ? (Windows 7 64 bits)
by mediavets » Thu Aug 26, 2010 6:36 pm
eric_222 wrote:I didn't try this new beta ... Why aren't we informed when there is an new version ?
For some reason Adrien only announced it on the English part of the APT sub-forum. Perhaps it's only an English version. I don't know.
Beta just means that software is evolving fairly rapidly at present, it doesn't mean it's not usable. Of course each new beta fixes issues that have arisen in earlier betas so it's best to keep abreast of new beta releases.
Kolor now plans to make APT available as a separate product rather than continuing to bundle it with Autopano Giga at which point I believe they may even plan to give it a different name (PanoTour?) - in the meantime hang in there because it gets better with every release.
I lose a lot of time to find solution in forums.(no information offline with the software !)
Another way of looking at it is that APT has probably saved you a lot of time compared to doing it all via hand coding XML?
Kolor has said that because the software is evloving quite rapidly they have chosen to devote their efforts to development of APT rather than forever trying to keep up with documenting a rapidly evolving product.
The best way to resolve issue/questions is to ask on the forum I think.
I'm sorry but I don't know - I suggest you try and install it and see.
I believe that issue is supposed to be fixed - again try it and see.
eric_222
by eric_222 » Thu Aug 26, 2010 10:54 pm
Thank you for fast answer.
New beta is Ok for solving my problem. Thanks
But, sorry, I don't agree with some elements of your post: when I buy a software or a product, I'd like the "manufacturer" indicates if the product has limits with such or such configuration, give explains for install, parameters of preferences, etc ...
Creating a simple panorama that produces result with "blacks lines" has nothing to do with earning time because no writing xml ... It's only having a product that can't do the minimum we are waiting for ....
I'm OK for not having offline 1000 pages or more of tutorials and help, but between nothing and 1000 pages, I think there are intermediate solutions. APT isn't a freeware.
A minimum could be asking the customer for giving his mail and some information, for having news by newsletter or something like that ...
I hope APT-Kolor will read this post and will give me advices for putting the right preferences for this new beta and my configuration.
Cordially
by mediavets » Thu Aug 26, 2010 11:10 pm
eric_222 wrote:Thank you for fast answer.
You'll find all there is for now on this page:
http://www.autopano.net/wiki-en/action/view/Main_Page
Adrien F
by Adrien F » Fri Aug 27, 2010 8:25 am
Je comprends tout à  fait votre point de vue concernant le manque de documentation.
Comme l'a très bien expliqué mediavets nous ne sommes pas une grosse équipe à  développer Autopano Tour, qui reste un logiciel jeune, et nous préférons nous concentrer sur l'ajout de fonctionnalités et la stabilisation du produit plutôt que sur la documentation.
Nous somme actuellement en phase de stabilisation du soft, et vous avez dû remarquer que les problème on rapidement étés corrigés (2 mois entre les deux dernières beta). J'espère que vous êtes, et serez, satisfait des changements.
De plus je tiens à  vous rappeler que le logiciel Autopano Tour beta 9 est une version *beta* que nous mettons à  la disposition du public afin de le faire profiter des dernières avancées et de lui permettre de participer à  son évolution. A ce titre, ce n'est pas le logiciel que vous avez acheté. Vous avez acheté une version stable (la 1.0.9) pour laquelle une documentation complète est disponible en français (http://www.autopano.net/wiki-fr/Accueil), ainsi que des vidéos de tutoriaux.
L'utilisation d'une version beta est soumise à  un accord tacite entre utilisateur et développeur :
- aucune garantie n'est fournie sur la stabilité du logiciel en question,
- des évolutions/régressions peuvent avoir lieu entre différentes versions,
- peu/pas de doc, mais nous nous efforçons de faire du support actif et rapide sur le forum et par mail,
mais en contrepartie:
- vous avez rapidement accès à  toutes les évolutions,
- vous donnez votre avis sur les fonctionnalités et nous essayons de les prendre en compte,
- vous pouvez proposer des idées de développement qui vous aideraient dans votre façon de travailler et nous essayons de les mettre en place dans la version suivante.
Comme l'a aussi dit mediavets, le projet arrive à  un certain degré de maturité et une version stable est en cours de préparation et devrait sortir avant la fin de l'année.
Je tiens à  m'excuser avoir oublié de mentionner dans le forum français qu'une nouvelle version beta était disponible je vais corriger cela sur le champs. Cette page est régulièrement mise à  jour pour notifier les dernières versions disponibles : http://www.autopano.net/wiki-en/Lastest_Beta .
Cordialement,
Adrien
