Hot spot fixe
Partagez vos trucs et astuces ici ou demandez de l'aide sur Autopano Tour !<br />
Pas de rapport de bug (de toute sorte) dans ce forum !
andebu
Hot spot fixe
by andebu » Sun Nov 21, 2010 12:12 pm
Je souhaite ouvrir un menu d'aide à  la navigation à  l'aide d'un hotspot à  placer dans les visites mais je souhaite que celui-ci ne tourne pas avec l'image, c'est à  dire qu'il reste fixe comme la barre de navigation.
Je vous remercie pour votre aide
Voici le hotspot que j'ai créé
Patrice
Canon EOS 7 D, Samyang 8 mm f 3.5, MANFROTTO 055XPROB, Nodal ninja NN 3 II
andebu
by andebu » Sun Nov 21, 2010 12:13 pm
Voici le hotspot
Liked in: 129 posts
by mediavets » Sun Nov 21, 2010 1:35 pm
Then you need to create your own theme.
Copy and modify one of the default themes.
andebu
by andebu » Sun Nov 21, 2010 1:47 pm
How should I do?, I have no idea
Patrice
Liked in: 129 posts
by mediavets » Sun Nov 21, 2010 2:27 pm
andebu wrote:Thanks
Patrice
First you need to be using Panotour Pro.
Then download the theme you will find here - which emulates the navigation menu style of Autopano Tour:
http://www.autopano.net/forum/t10301-apt-menu-into-panotour-pro
Look at the elements that make up the theme and modify it to suit your needs with your own graphics.
Good luck.
Liked in: 129 posts
by mediavets » Sun Nov 21, 2010 3:24 pm
If instead you wish to continue working with Autopano Tour then take a look at these alternative navigation menus for APT 1.1 beta 6 or later.
They will give you an insight into how to create your own and can form a 'template' to work from/modify.
http://www.autopano.net/wiki-en/action/view/APT_resources_menu_gk_20100119_01
andebu
by andebu » Sun Nov 21, 2010 4:36 pm
Dear Andrew
Thank you, using pano tour pro resolved my problem as you can see on the following image.
Regards
Patrice
andebu
by andebu » Sun Nov 21, 2010 4:37 pm
image coming , hope so
andebu
by andebu » Sun Nov 21, 2010 4:38 pm
Comment ferais-je sans vous !!!!
Encore merci pour votre aide
Patrice
andebu
by andebu » Sun Nov 21, 2010 4:40 pm
For the alternative menus you proposed me, I already installed them but could not display a help menu. My solution was to use PANOTOUR PRO.
Sorry for my poor english
Patrice
