new site
homer39
new site
by homer39 » Sun May 09, 2010 9:56 pm
go to www.skydome360.com and click on "Visites Virtuelles a 360°" very complete tour with many options, specials effects (water in bathroomm, smoke on roof...) and a mail contact form include! how to do that?
A home flash plugin? anyone knows how to do that?
by mediavets » Sun May 09, 2010 10:53 pm
homer39 wrote:go to www.skydome360.com and click on "Visites Virtuelles a 360°" very complete tour with many options, specials effects (water in bathroomm, smoke on roof...) and a mail contact form include! how to do that?
It was done by hand coding XML format commands for the krpano Panorama Viewer.
You could do something very much less elaborate very easily using Autopano Tour.
homer39
by homer39 » Sun May 09, 2010 11:10 pm
I'm not sure it's easily, advandced xml coding!
homer39
by homer39 » Sun May 09, 2010 11:13 pm
The floor plan change when your are interior/exterior, and i have no idea to do that
by mediavets » Sun May 09, 2010 11:27 pm
homer39 wrote:I'm not sure it's easily, advanced xml coding!
Yes, I'm quite certain it is very advanced XML coding.
You are probably more likely to find expert XML coders on the krpano forum:
http://krpano.com/forum/wbb/index.php?l=2
On the other hand if you are willing to forgo some of the 'bells and whistles' (many of which seem rather gimmicky to me anyway) then you can create less elaborate virtual tours very quickly and easily using Auropano Tour.
jeromy27
by jeromy27 » Mon Jun 14, 2010 7:28 am
This forum is must for people like me.
Regards
jeromy27
