Embed Video in your tour
NeOnMedia
by NeOnMedia » Thu May 06, 2010 3:03 pm
I'm trying to embed a video in my tour,
Does anyone know how i can do this?
Or has an idea about an alternative way?
Thanks,
by mediavets » Thu May 06, 2010 3:44 pm
Welcome to the forum...
It would have been more appropriate to post in the topic "Using Autopano Tour":
http://www.autopano.net/forum/f18-using-autopano-tour
But never mind...
NeOnMedia wrote:Hello,
Thanks,
You are using Autopano Tour (APT)? Then make sure you have the latest beta release - V1.1 beta 7:
http://www.autopano.net/forum/t7116-apt-v1.1-beta
Then you specify video (.FLV) as the Display-Object (fill) within a Rectangular hotspot, as the Display-Object for a Point hotspot or as the Link-Object (target) of all types of hotspots.
Screenshots show selection of an FLV file as the Display-Object for a Rectangular hotspot, and what it looks like when you play the tour:
NeOnMedia
by NeOnMedia » Wed May 12, 2010 9:37 am
Thanks for your reply, but i'd like to use video in the following maner:
i'd like to make a hotspot in the 360tour on which the visitor can click. A pop-up within the window apears (same as a picture) in which the video starts playing. Do you also know which video file formats are supported?
thanks in regard!
by klausesser » Wed May 12, 2010 1:50 pm
mediavets wrote:Screenshots show selection of an FLV file as the Display-Object for a Rectangular hotspot, and what it looks like when you play the tour:
Hey Andrew!
Well done - good explanation!
by klausesser » Wed May 12, 2010 1:52 pm
NeOnMedia wrote:Thanks for your reply, but i'd like to use video in the following maner:
thanks in regard!
Hi!
I suggest to visit the KRPano forum because you need to deal with the features of
KRPano-tools if you want to exceed the features of APT.
by mediavets » Wed May 12, 2010 4:00 pm
thanks in regard!
Then try it this way with the video file as the Link-Object - is this what you had in mind?
The screenshots show this using a point hotspot but it works the same way with a polygon hotspot or a rectangular hotspot.
The only video format supported is Flash video .FLV.
http://en.wikipedia.org/wiki/Flash_Video
