Falkensteiner Cave Germany 360° Tour
micha22
by micha22 » Thu Jan 21, 2016 10:36 pm
it´s winter and i have time to do some free work just for fun.
http://sem-s.de/k/falkensteiner-hoehle/360falki.html
A cavingtour in the " Falkensteiner Höhle" near Bad Urach in south germany.
8 hours for 7 panoramas, setting the lights was a lot of work.
We want to go deeper in the cave, but we were surprised by the high water level and we was stopped by the first half-sump which is normally 5 inches air between the rock-ceeling and the water.
Sadly we have let our cavedivingequipmet at home ;-(
To be continued...
Michael
2 people like this post.
RoJa
Liked in: 19 posts
Re: Falkensteiner Cave Germany 360° Tour
by RoJa » Tue Jan 26, 2016 7:17 pm
What is wrong then here? So a great tour and nobody writes a post? Then I will start.
The tour is a masterpiece. Magnificently! Great resolution. Wonderful colours. Technically at the highest level.
Question: how you have illuminated the cave and which equipment (camera, objective...) you have used. And: how cold was it in the cave and how long you have needed for the admission of the pictures?
Greetings, Ronald
Was ist denn hier los? So eine tolle Tour und keiner schreibt einen post? Dann werde ich anfangen.
Die Tour ist ein Meisterwerk. Grandios! Tolle Auflösung. Wunderschöne Farben. Technisch auf höchstem Niveau.
Frage: wie hast Du die Höhle ausgeleuchtet und welche Ausrüstung (Kamera, Objektiv...) hast Du benutzt. Und: wie kalt war es in der Höhle und wie lange hast Du für die Aufnahme der Bilder benötigt?
Grüße, Ronald
micha22
by micha22 » Tue Jan 26, 2016 9:13 pm
Hello Ronald,
thanks for your praise!
To illuminate we used two Scurion 1500 http://www.scurion.ch/jm/index.php?option=com_content&view=article&id=155&Itemid=109&lang=de from my friend.
This lamps give a soft light beam without any shadows and two led lamps with 1000 lumens
on two tripods to place behind the actor or a corner. I shoot 6 pictures around, one up and two down.
For every picture we set the light specially but we regard to the transitions between the pictures.
So every 360°pano takes about one hour.
The temperature in the cave was 8 degrees celsius and the water temperature the same.
Camrea was a nikon d600 with a 16 mm 2.8 fisheye, iso 50 and f 13.
Regards
michael
jpdeglet69
Liked in: 7 posts
by jpdeglet69 » Tue Apr 19, 2016 1:46 pm
Of course, caving I like it!
Can I add (or you) a link on your realization at
https://fr.wikipedia.org/wiki/Sp%C3%A9l%C3%A9ologie section "La pratique virtuelle et démocratisée"
and
https://en.wikipedia.org/wiki/Caving section "cave conservation"
BR
JPhD
gabriel
Likes: 15 posts
Liked in: 13 posts
by gabriel » Tue Apr 26, 2016 4:47 pm
Very Very good shoots ! Congrats
