Hot Spot Yoga Studio | Virtual Tour
Octavias
by Octavias » Tue Apr 23, 2013 6:22 am
Hey everyone,
After some gear upgrades and lots of reading i have completed another tour of a Yoga Studio. Please check it out and give me some feedback.
I think stitch was a success this time, i really enjoy the colors as well.
What I want to know mostly is all of your opinion on the Top drop-down pano size. I made it big so it covers the logo when its down, but i might wanna make it small?
Any additions to the tour are also welcomed. I want to target Yoga studios so i want this tour to be presentable as possible.
http://www.acmbphotography.com/Hotspotyoga/build/virtualtour.html
Thanks in advance to all of you! :D
-Max
"The whole point of taking pictures is so that you don’t have to explain things with words."
http://www.acmbphotography.com/ - website
https://www.facebook.com/ACMBPhotography - facebook
https://www.facebook.com/MaxBolotovPhotography
by mediavets » Tue Apr 23, 2013 9:19 am
I've never liked the look of the PTP 1.8 drop down/slide out thumbnails bars - they look ugly and the tab isn't obvious nor is its function - I doubt many people will even find it.
I would prefer a thumbnail stack vertical from the top right that starts open. It would be best if it remained open but you can't specify that from the PTP GUI but I expect you could modify the XML.
The music would drive me away - but then I'm not a target customer. Won't you need some sort of license to use that music? Does this yoga studio specialise in a new type of Jamaican yoga? ;)
There's something going on with text tooltips - see screenshots - are you using a font that's not on my system or something?
UK Pano
by UK Pano » Tue Apr 23, 2013 9:43 am
How about editing the title of the html page from "Virtual Tour generated by Panotour"?
Octavias
by Octavias » Wed Apr 24, 2013 6:28 am
Hey guys!
Appreciate the awesome input. Here is he new tour with the corrections and my own modifications. Let me know if the font works now, i used a basic one. Also does the tour load sooth for u guys, should i make change in h pano size? I read about "Cutting size" and "Cube faces size" but they really don't explain how it would effect the tour. Help!
http://www.acmbphotography.com/Hotspotyoga/build/Hotspotyoga.html
-Max
UK Pano
by UK Pano » Wed Apr 24, 2013 9:45 am
Yep fonts fixed and load well for me Max. Mediavets will have the answer on the tile sizes. Something to do with zooming resolution and loading time I think!
by klausesser » Wed Apr 24, 2013 11:09 am
404 page not found.
by gkaefer » Wed Apr 24, 2013 1:35 pm
cool. creating a pano with a hotspot named hotspot because its a Studio named hotspot :D
like it...
by gkaefer » Wed Apr 24, 2013 1:37 pm
Octavias wrote:Hey guys!
-Max
did you use the "optimize" button in ptp1.8?
I never took time to get into Details here, but my experience was to use the "optimize" button never Fails...
Octavias
by Octavias » Wed Apr 24, 2013 5:31 pm
klausesser wrote:
404 page not found.
Klausesser,
use the NEW updated link
Thanks guys!
Octavias
by Octavias » Wed Apr 24, 2013 5:34 pm
-Max
Yea, that's what i have it set to right now. Thanks guys!
Also, I am really thinking about the "MUSIC" and the licencing situation. I do not know how to advise my client since this will be for commercial use should we consider using a license free music of some kind?
Thanks guys!
by mediavets » Wed Apr 24, 2013 6:09 pm
Yes, fonts are OK now.
I would make the Thumbnails a lot larger and probably would have a bigger border to attact the user to click on them.
I would probably drop the hotspots for navigating between rooms - the routes in and out of the rooms are hardly of real interest to potential customers in this instance - might be different if it was a real estate tour.
Will people realise they can click on the schedule on the counter to see a larger legible view?
-Max
It seems to load OK for me and I have relatively low bandwith (1.5mbps at best) ADSL Net connection here in the UK.
I woud leave everything on default and use that 'optimise switch' that Georg mentioned. Multiresolution should take care of the rest and you should never select 'embed all data'.
I don't have an iDevice but is your tour intended to be viewable with iDevices as well as Flash-enabled platforms?
If so, is it?
Octavias
by Octavias » Tue May 07, 2013 9:44 pm
Thanks for all of your comments guys, The client really loved it and it was an awesome learning experience.
Next point is to perfect my nodal point. I can't seem to make a perfect stitch and when i shoot my nadirs they don't add up perfect since the lens is not centered. I took a ruler and measure the center and then applied the math to my Panosaurus Pano head, but still I am getting error in my stitch. Any advice?
-Max
jacobus182
by jacobus182 » Thu May 23, 2013 8:06 am
Octavias wrote:Thanks for all of your comments guys, The client really loved it and it was an awesome learning experience.
-Max
Hi Max
I also use a Panosaurus, i got slight parralax errors too. i then took the time to adjust it by following this guide http://www.youtube.com/watch?v=zEgLgReARxs&feature=share&list=PLYdAm5x3l4m5aTZWLBtIhC4nkCkHOUUoc
Also do you use a bubble level? i check that im level on each shot. That works for me, now i have almost no shift from one shot to the next.
Regards
Jacob
