Furniture shopping complex "SCARAB"
Variety
by Variety » Mon Feb 25, 2013 2:46 pm
Did not win the tender, three scenes were ...
http://www.hdrl.ru/VT/0002/vtour/tour.html
Regards,
Dmitry
www.hdrl.ru
teddy
by teddy » Mon Feb 25, 2013 10:19 pm
Excelent !
Please, tell us: what template you use for the Control Bars?
Tks,
sasha_che
by sasha_che » Mon Feb 25, 2013 10:53 pm
I believe its the standard Krpano template
Variety
by Variety » Mon Feb 25, 2013 10:59 pm
All right! The standard pattern - http://www.krpano.com/
teddy
by teddy » Tue Feb 26, 2013 10:51 am
In Panotour 1.8 have not this.
Variety
by Variety » Tue Feb 26, 2013 1:12 pm
Panotour 1,8 - program for beginners! Purchase the program, you get a license and http://www.krpano.com/
After reviewing the program - you can do whatever you want ....
Any options menu and decoration - http://hdrl.ru/kalinA/tour.html
Regards,
Dmitry
www.hdrl.ru
teddy
by teddy » Tue Feb 26, 2013 8:29 pm
Don't understand. You use Panotour 1.8 + another program to make those tours?
I use only Panotour 1.8 -demo, yet.
by gkaefer » Wed Feb 27, 2013 12:46 am
teddy wrote:Don't understand. You use Panotour 1.8 + another program to make those tours?
if you buy panotour pro 1.8 than also a krpano license is included/embedded.
panotour pro 1.8 can create tours where the config is not embedded (I think is most cases this is Default usage) and saved as XML files. These files use the Syntax of krpano...
so back to the tour shown above... that means he did use his krpano license from his panotour pro 1.8 Version and did create the tour only with krpano.
krpano does come with scripts and droplets and view binaries you can use to create also simple (but with no GUI like panotour pro 1.8) tours like the shown...
you can download the krpano package and use your licenses exported from panotour pro 1.8.
The panotour 1.8 (non pro) does this not provide...
with next coming panotour 2.0 Version it will becom official GUI for krpano language and all krpano code will than b supported from inside the panotour 2.0 GUI.
(this is currently not the case). the release date is not known until now. It will most likely exist an upgrade path like in past Upgrades: if you buy x months before new Version release the old one the upgrade will be free. All other existing users will get an reduced Price for the upgrade. Upgrades are only to pay with Major release Upgrades like from 1.x to 2.x but not within the Major release...
teddy
by teddy » Wed Feb 27, 2013 9:02 am
Tkank you, gkaefer
