Working with Scenes
Got some great idea or a feature request? Post it here and discuss it. The most requested concepts are usually implemented, as Autopano Tour is very community driven.
Maw.
Working with Scenes
by Maw. » Mon Jun 14, 2010 1:34 pm
I would like that Autopano Tour will work with Scene in Future.
Is that planned? I think it´s the better technology in krpano.
Regards
Marc
by gkaefer » Mon Jun 14, 2010 1:57 pm
do you mean: http://krpano.com/forum/wbb/index.php?page=Thread&threadID=514 ?
newest APT beta is based on a newer krpano version, so <scene> should be possible with APT (manually adding this later...)
but yes would also be fine to have these funtions from inside the GUI...
Maw.
by Maw. » Mon Jun 14, 2010 2:10 pm
yes, I mean these <scene>´s in krpano since 1.0.8 beta 7.
hope that in future a krpano-tour with APT will be generated via <scene>´s
Marc
Adrien F
by Adrien F » Tue Jun 15, 2010 11:14 am
Could develop a bit more the use you do of the <scene> attribute and how you see it fitting in APT?
Maw.
by Maw. » Tue Jun 15, 2010 6:13 pm
I jus thought about, that the automatical creation of a tour in autopano don´t create lots of seperate xml files, but just one with all the panos in it, by using "scenes".
