Indirection file export for developpers
Got some great idea or a feature request? Post it here and discuss it. The most requested concepts are usually implemented, as Autopano Tour is very community driven.
Adrien F
by Adrien F » Tue Jan 26, 2010 4:11 pm
As said by scraff in a previous post, some changes can happen in the correspondence between xml names and the linked panorama (when saving a project, manipulating history, deleting pano, adding some new). This lead to problems for users doing dynamic visits (
Allowing the user to manually name the xml files raises some issues:
a - unicity of pano identification is no more guaranteed
b - krpano XML parsor isn't reliable enough for this kind of stuff : commas, blank spaces and other quotes character may break your visit.
A solution would be to export an additional XML file containing an indirection table:
    <pano name="visit10" filePath="C:/Img/myPano1.jpeg" xmlFile="visit10.xml" ... />
This would allow a advanced post-treatment for website generation.
It also implies to add a check box in the user interface which is quite heavy yet.
Questions are the following:
Who would benefit from such a feature?
Wht would you like to see in the xml file?
