[APT 1.1.0b10] European Keyboard Support
b4de4nd
by b4de4nd » Wed Aug 25, 2010 6:49 pm
Hi!
GREAT great new tour program... much faster to render tours and nice with the new features as little planet introduction, sound working great, and lots lots more...
However... the one problem im having is the support for the à¦à¸à¥
i use danish language in my menu´s and i have an option for full screen, which in danish would be "fuld skà¦rm" however, a generated tour now shows the text visible in this picture.
The menu in the image list shows the names fine with sà¸kanten...
Adrien F
by Adrien F » Thu Aug 26, 2010 10:11 am
The problem comes from the fact that your menu templates are not encoded in UTF8 as the software assumes.
UTF8 is a standard text encoding mode which allows a very wide range of charaters (including à¦à¸à¥). Windows do not use it by default (it uses Latin-1).
The solution : use an advanced text editor which allows utf8 encoding or conversion. Notepad++ is a free and very good one.
b4de4nd
by b4de4nd » Fri Aug 27, 2010 9:37 am
my menu templates are edited in dreamweaver cs5.... its not an option to use that program then ? and why did it work in the previous version ?
ill look into the problem and try out the notepad++
thx!
