Name of source file
HansKeesom
Name of source file
by HansKeesom » Sun Aug 22, 2010 2:49 pm
When I am working in autopano tour I can change the name of a pano into a more readable form. However by doing this I loose the filename of the original file that was used. I do want to know that as sometimes I need to repair something.
As my virtual tours are over 20 pano's big sometimes, I would like to see a properties tab next to the Pictures Parameters tab that show me the path and filename.
Regards, Hans Keesom
by mediavets » Sun Aug 22, 2010 4:38 pm
HansKeesom wrote:When I am working in autopano tour I can change the name of a pano into a more readable form. However by doing this I loose the filename of the original file that was used. I do want to know that as sometimes I need to repair something.
You can use the Extended save as feature to place all resources in one location.
HansKeesom
by HansKeesom » Sun Aug 22, 2010 7:28 pm
Nice, but not at all what I am asking for. I want to know directory and filename of the jpg that is in a given autopano tour project so I can edit when needed. The option shown has nothing to do with that.
by mediavets » Sun Aug 22, 2010 7:34 pm
HansKeesom wrote:Nice, but not at all what I am asking for. I want to know directory and filename of the jpg that is in a given autopano tour project so I can edit when needed. The option shown has nothing to do with that.
It has something to do with it, because all the source panos for the tour panos would then be in (copied to) one directory. And then it's quite easy to identify them I think.
