[APT 1.0.9] Wont locate renamed images
getho
by getho » Tue Aug 10, 2010 1:26 am
I just get an error box saying "Can't create image from file: D:/path/filename.jpg"
I click OK and nothing loads.
The old version used to, is there a workaround?
renan
by renan » Tue Aug 10, 2010 8:39 am
If we can't open one picture the loading failed.
The map file is not currently checked for relocating. So open failed if map picture location changes.
This will be corrected in next beta.
Can you confirm me that your picture was the map file ?
