APT 1.0.9 problem when starting the 64bit windows7
Oxygen02
by Oxygen02 » Fri Jul 09, 2010 10:41 am
Hi
I have a problem ...
When I tried to apt (64bit) in Windows 7 64bit get the message
OMP: Warning # 2: Can not open message catalog "1045 \ libiomp5ui.dll"
SMP: System error # 126: Can not specified module can found.
OMP: Info # 3: Default messages will be used.
when I close the window with this message APT off
Please help.
problem nie występuje w APT 1.1 beta5
Canon 7D, Nikon D70, Samyang 8mm f/3.5 MC fisheye, Samyang 85 f/1.4 MC, Nikkor DX 18-70 f/3,5-4,5G ED, Nikkor 70-300 f/4-5.6G, Nodal Ninja 5, AutoPano Giga, tripod RACAM 6165, Acer Extensa 5220 (Core2duo 2Ghz, 3GB Ram, 120GB HDD, WIN 7 64bit)
by mediavets » Fri Jul 09, 2010 11:33 am
Oxygen02 wrote:Hi
Please help.
Have you tried the latest version - V1.1 beta 9?:
http://www.autopano.net/forum/t9204-apt-v1.1-beta-9
Oxygen02
by Oxygen02 » Fri Jul 09, 2010 7:06 pm
problem does not occur in APT 1.1 beta5
I found a solution for ATP 1.0.9
downloaded from the Internet libiomp5ui.dll file and copied it to the directory:
c: / windows/system32/1045/libiomp5ui.dll
and everything works.
by mediavets » Fri Jul 09, 2010 8:03 pm
Oxygen02 wrote:problem does not occur in APT 1.1 beta5
APT 1.0.9 has been superceded by APT 1.1 beta 9 as mentioned in my previous post:
http://www.autopano.net/forum/p66068-today-11-33-16#p66068
