[APT V1.1 beta 9 WinXP32] picture size settings not saved
RickDrew
by RickDrew » Wed Jul 07, 2010 10:55 pm
Not sure if this is a bug or not - when I click "calculate optimal size" under Panorama Properties, a partial width, cutting size, etc. are populated. I save and exit. Next time I go to that area, the original settings are there, not the new calculated sizes.
Adrien F
by Adrien F » Thu Jul 08, 2010 8:24 am
This is not the normal behavior. Clicking on "Compute optimal size" should only change cube face size / partial panorama width, no cutting size.
And saving the project after changing those values should permit to reload them exactly as they were saved.
I tried with both 32 and 64 windows versions and it seems to work.
Do you have the krpano registred? Could you save your project under a different name and open this later to check the size?
