[APT V1.1 beta 9 WinXP32] Map
RickDrew
by RickDrew » Wed Jul 07, 2010 10:42 pm
The map does not update when changing panoramics, either with the drop-down or links. It's a cool feature and easy to use! Any chance of adding a radar?
by mediavets » Wed Jul 07, 2010 11:45 pm
RickDrew wrote:The map does not update when changing panoramics, either with the drop-down or links.
You say 'does not update'...but this was something fixed in beta 9 and it works for me, with a map, drop down, hotspots and thumbnails.
RickDrew
by RickDrew » Thu Jul 08, 2010 3:43 am
[APT V1.1 beta 9 WinXP32] - does not update for me- Is there any XML code I need to enter?
by mediavets » Thu Jul 08, 2010 7:52 am
RickDrew wrote:[APT V1.1 beta 9 WinXP32] - does not update for me- Is there any XML code I need to enter?
No special coding is required.
Did you perhaps make this tour originally with an earlier version and update it with beta 9? Just an idea.
I created my test example from scratch with beta 9.
RickDrew
by RickDrew » Tue Jul 13, 2010 4:11 am
Yes - It was created in an earlier version, then opened and edited in the beta version. One created in the beta version from scratch works fine. Take that back. After I added the three new panos, it no longer works correctly. Plus, the styles of the hotspots get messed up. Wrong icons or no icons.
Adrien F
by Adrien F » Tue Jul 13, 2010 9:34 am
I would be interested in your APT project file created with the earlier version (hence the one which does not work in beta 9).
I would also like to have a look at the second one (created from scratch in beta 9), if you provide me the exact steps to reproduce the problem, and the description of the problem.
You can send all this via private message.
Thank you.
