[APT V1.1 beta 9 WinXP32]Extended save as
by mediavets » Fri Jun 25, 2010 12:12 am
I am really pleased to see the new 'Extended save as' feature, but...it's only available from the icon and I feel it should also be available via the File menu.
by gkaefer » Fri Jun 25, 2010 2:42 am
stupid question...
what should be the difference between Icon "save extended as" and File menu "Save as" - in both cases windows is opening where I can safe my *.apt with no single different option? Both opened windows are named "Save as"...
Win7 64bit...
by mediavets » Fri Jun 25, 2010 7:39 am
To quote Adrien from the V1.1. beta 9 Changelog, New features, Import/Export:
http://www.autopano.net/forum/p65360-yesterday-14-33-29#p65360
"** extended save as : save the project PROJECT.apt and copy all necessary files to a folder PROJECTsources/ at the same place"
by gkaefer » Fri Jun 25, 2010 12:16 pm
mediavets wrote:To quote Adrien from the V1.1. beta 9 Changelog, New features, Import/Export:
;-) ok thanks - on one side its fantastic to have such an amount of new features... but other side its so much lines to read ;-))))
