[APT V1.1 beta9 WinXP32]Where has nadir patch gone to?
by mediavets » Fri Jun 25, 2010 12:10 am
The nadir patch feature seems to have disappeared?
Liked in: 14 posts
by gkaefer » Fri Jun 25, 2010 2:36 am
no - same position than in beta 7...
digipano
by digipano » Fri Jun 25, 2010 4:20 am
No its not visible to me either, seems it broken.
by mediavets » Fri Jun 25, 2010 7:31 am
Aha, I got it back.
I'd been playing with the Crop feature on a 360x180 pano image and if you reduce the Pano FOV from 360x180 then the Nadir patch part of the Panorama properties/Picture parameters dialogue disappears because it no longer applies.
I had then resized the crop box to show the full 360x180 but to recover the Nadir patch parts of the dialogue you then also need to click on the pano image in the main panel to refresh the Panorma propreties/Picture parameters dialogue.
