tour start point problem
parisbyphoto
by parisbyphoto » Thu Jun 24, 2010 10:22 am
I have created a simple tour of Montmartre comprising 3 360 photos covering the lower, middle and higher levels of the approach to the Sacre Coeur. The problem is, I selected the bottom to be the start point for the tour, but instead of displaying the bottom, it displays the top. I can click on the middle and then on the bottom to actually see the bottom, so I did use the correct 360. Any ideas? I have tried this twice with errors. I have not encountered the problem before. You can see the 360 on this page at the bottom: http://www.parisbyphoto.com/sacrecoeur/
I am using B7.
Adrien F
by Adrien F » Thu Jun 24, 2010 11:02 am
The visit on your website starts at the bottom. Did you finally solved your problem?
parisbyphoto
by parisbyphoto » Thu Jun 24, 2010 11:56 am
Hi, yes, I just created it again and it seems to have solved the problem. I suppose it was probably user error. Sorry to have wasted your time.
