AutopanoTour 1.1.0 beta7 - APPCRASH
InPicCom
by InPicCom » Wed Jun 09, 2010 3:18 pm
I try to make a virtual tour which consist of the two tiff 360 panoramas and one map. OS - WIN 7.
At render I have got a crash. It is indicate - APPCRASH. I guess it is problem of win7 and a log file but may be someone know how to cope with this problem?
by mediavets » Wed Jun 09, 2010 3:35 pm
InPicCom wrote:I try to make a virtual tour which consist of the two tiff 360 panoramas and one map. OS - WIN 7.
Welcome to the forum...
What are the pixel dimensions and filesizes of the two panoramas and the map?
Why are you using TIFFs?
How much RAM does your system have?
InPicCom
by InPicCom » Wed Jun 09, 2010 3:39 pm
Tiff files size 134 and 250 mb.
The map 200 kb.
Tiff for better quality.
RAM 0 4,0
Thank you in advance!
by gkaefer » Wed Jun 09, 2010 3:42 pm
you write during render your get a crash...
autopano tour does not render (it only tiles your pano made with autopano pro or giga into several slices)...
so do you mean while rendering in Autopano Pro/Giga (APP/APG)?
by gkaefer » Wed Jun 09, 2010 3:48 pm
InPicCom wrote:Tiff files size 134 and 250 mb.
The map 200 kb.
RAM 0 4,0
if your target is a website where audience can review your Tour than jpg as imput will be enough quality. I doubt using tiffs here can give you a better result
APT finlly takes you imput pano and as output jpg slices are created...
edit: or does it slice tiff into small tiffs? really unsure never tried it...
addon: your write 360panos... so make sure your source panos have exact 2:1 relation of the pixel width:heigth and you choosed spherical output projection...
did you edit the tiffs with external programs? like photoshop perhaps an alpha layer added?
InPicCom
by InPicCom » Wed Jun 09, 2010 3:55 pm
gkaefer,
Yes of course Autopano Tour is not render but exporting, sorry.
Now I have exported with jpeg files so it is work and export well.
For this project it is ok but later I will need the largest files with ultimate quality. I'm afraid jpeg is not well for this and AutoPano Tour again produce the crash.
Thank you very much for comments!
InPicCom
by InPicCom » Wed Jun 09, 2010 3:57 pm
Yes it is slice jpeg so.. I will not get the quality...
InPicCom
by InPicCom » Wed Jun 09, 2010 3:59 pm
Yes I use Photoshop but all ok with size and etc.
Thank you Georg!
by gkaefer » Wed Jun 09, 2010 4:04 pm
InPicCom wrote:Yes it is slice jpeg so.. I will not get the quality...
ok if you want more quality...
what are your settings in APT:
did you "Compute Optimal Size"
reduced "cutting size" to say 500
Jpeg Quality? 12 = maximum and makes really big (and slow even with 8mbit access) panos... so my experience is best performance/quality level is 10
if you want quality you def. seek for a krpano license (former unlimited krpano domain license)
and gigapixel you'have to wait for next APT releases (announced...) or alternativley use commandline tools krpano (www.krpano.com) (license you can buy at kolor....)
than multiresolution with gigapixel brings a quality boost already...
InPicCom
by InPicCom » Wed Jun 09, 2010 4:11 pm
I have made cutting size 300.
I have bought a license of krpano some days ago so will use it for the largest panos. :) But I thought that I can do big files at Autopano Tour.
by gkaefer » Wed Jun 09, 2010 4:34 pm
InPicCom wrote:I have made cutting size 300.
yes but for highest possible output you need krpano license and fiunally doing your tour with APT and afterwords redoing the slicing with krpano tools manually
InPicCom
by InPicCom » Wed Jun 09, 2010 4:40 pm
Georg,
I guess I need to find out a lot about krpano.
Hope I can cope with it :)
Best wishes,
Aleksey
