Can no longer output XML?
Swoody
by Swoody » Thu May 06, 2010 6:15 pm
HI,
It's been awhile since I used AutoPano Tour and APT V1.1.0 beta 7 (full license) but for some reason I can no longer output XML for tweaking. The option to uncheck "Embed XML" is GRAYED OUT. I am also having the same problem with SOUND in beta, but I've already posted that as another issue elsewhere here. Worth mentioning though, since it seems to be a theme.
I want to tweak my XML, because I keep getting feedback (as others here have) that the auto rotation is too FAST, and as far as I can tell, there is no way to tweak that without going into the XML (?)
Mac, Snow Leopard 10.6.3
Thanks in advance for any help
Best,
Sara
Mac Dual-Core Intel Xeon, 12 Gb RAM (OS 10.6.4) APT V1.1 beta 11 (Autopano Giga + Krpano license)
by mediavets » Thu May 06, 2010 8:02 pm
Swoody wrote:HI,
Best,
Sara
See:
http://www.autopano.net/forum/p62867-today-20-00-11#p62867
I think this is the same issue as your Sound option being grayed out.
Swoody
by Swoody » Thu May 06, 2010 9:31 pm
You are correct- THANKS! Went through again and re-directed to the license files. Works now - THANK YOU!
