[APT beta 7 Mac OSX] Have to scroll to see all properties
Maw.
by Maw. » Sun Mar 14, 2010 2:11 pm
It´s very disgusting - I haven´t found the map settings because the Project Properties Window has very big width and I need to scroll a lot to see the tabs "Interface, Logo, Map, Font, Sound, Thumbnail"
That´s very bad usability because for all settings I always have to scroll a lot in horizontal way, as you see in image
System: Mac OSX 10.6.2
Regards
by mediavets » Sun Mar 14, 2010 2:58 pm
This must be a Mac bug - but it seems odd that no other Mac users have reported it.
Maw.
by Maw. » Sun Mar 14, 2010 3:04 pm
I hope that some others will report, because it´s a clean install of the software
zanya
by zanya » Wed Mar 24, 2010 5:18 pm
it's the same for me ! I thought most of the program was gone !
manuel rosario
by manuel rosario » Thu Mar 25, 2010 1:59 am
The project properties table, i think, can be resized, It fits nicely on the small screen (13"), half of right side, so I do not have to scroll. I have macbook pro 13.3 in with snow 10.6.2. FYI.
cheers,
manny
Canon EOS20d, 50d, sigma 12-24, samyang 8mm FE, 4GB ram, 2.53 GHz MacBook Pro 13.3 Snow 10.6.8, Panosaurus, Nodal Ninja NN3II, AutopanoGiga+PTP, KRPano Unlimited, Photomatix4, onOne PhototoolsPro 2.6 and Perfect Resize 7, Noiseware Pro, Topaz Suite, PS CS5.
Maw.
by Maw. » Thu Mar 25, 2010 7:29 am
but mine is on a 15" and fits on 1/3 of screen size, but it must be a bug because zanya has the same problem...
Maw.
by Maw. » Fri Jun 11, 2010 2:12 pm
so now using Autopano Tour 1.0.8 and where´s the map-feature now??
now tabs, no scrollbars:rolleyes:
Marc
manuel rosario
by manuel rosario » Fri Jun 11, 2010 2:35 pm
Those features are in the APT 1.1 beta 7. I am using it and works fine. I enhanced this by KRpanotools. Pls try APT 1.1 beta 7.
Manny
Maw.
by Maw. » Fri Jun 11, 2010 3:07 pm
oh, it was a mistake of mine because of 1.1 beta 7 and then the new version 1.0.8 I thought this would be the new one ;-)
thanks!
