[APT V1.1 beta7] Deleting hotspots from Map image
by mediavets » Tue Mar 09, 2010 5:21 pm
Saved and re-opened an APT project which includes a Map with hotspots.
Attempting to delete a hotspot from the Map image causes the program to hang.
Adrien F
by Adrien F » Wed Mar 10, 2010 9:36 am
Thank you for reporting, I was able to reproduce it, I'll investigate it soon.
by mediavets » Wed Mar 10, 2010 10:13 am
Adrien F wrote:Thank you for reporting, I was able to reproduce it, I'll investigate it soon.
OK - while looking into that issue perhaps you would also consider adding the Select button to the Hotspot editor: Map that exists in the Hotspot editor:Panorama. It would make selecting map hostpots much easier, just as it has for selcting/editing panorama hotspots.
