[APT beta 7] thumbnail intro animation
Adrien F
by Adrien F » Wed Feb 24, 2010 5:14 pm
Which solution do you prefer?
1 - http://ftp.autopano.net/tmp/demoThumbIntro/thumbnailBling.swf
2 - http://ftp.autopano.net/tmp/demoThumbIntro/thumbnailOut.swf
3 - keep thumbnail out of screen until clicked
4 - keep thumbnail in until clicked
by gkaefer » Wed Feb 24, 2010 5:36 pm
to be honest:
to have the choice inside APT to choose the one preferred... (and this may in different projects be sometimes 1,2,3 or 4)
by mediavets » Wed Feb 24, 2010 6:03 pm
gkaefer wrote:to be honest:
I agree.
jmbphotoworks
by jmbphotoworks » Wed Feb 24, 2010 6:27 pm
I agree as well. Is there a way to get the thumbnails to scroll?
digipano
by digipano » Wed Feb 24, 2010 7:35 pm
Both should be an option within APT with additional option of some animated text or flashing graphic/arrow on the bar which can read "click here for thumbnails" so if the bar shows by default & then slides back after few second the user would still know & can see the animated text, if the bar is off by default same is applicable to it.
Thumbnail scrolling is a very much required feature specially when you have more than 10-12 images in a tour. By providing scrolling we can exactly set size of thumbnails we want, on large screens set with higher resolution its very much required feature.
BrianLR
by BrianLR » Thu Feb 25, 2010 4:04 am
digipano wrote:Both should be an option within APT with additional option of some animated text or flashing graphic/arrow on the bar which can read "click here for thumbnails" so if the bar shows by default & then slides back after few second the user would still know & can the animated text, if the bar is off by default same is applicable to it.
Thumbnail scrolling is a very much required feature specially when you have more than 10-12 images in a tour. BY providing scrolling we can exactly set size of thumbnails we want.
I agree will all of the above comments.
by mediavets » Fri Feb 26, 2010 9:12 pm
I like the way the thumbnails work/animate in this pano:
http://www.ciudadcubica.com/JJosePedroCasa/
