APT 1.1.0 Beta 7 - Thumbnail window pops up on loading
BrianLR
by BrianLR » Thu Feb 11, 2010 5:08 am
I find that with APT 1.1.0 Beta 7 - the Thumbnail window pops up on loading, this did not happen with beta 6 , is this intentional, it would be best if the was an option that could be set rather than happening whatever.
Brian
by mediavets » Thu Feb 11, 2010 9:11 am
BrianLR wrote:I find that with APT 1.1.0 Beta 7 - the Thumbnail window pops up on loading, this did not happen with beta 6 , is this intentional,
Yes, apparently the default behaviour was changed in Beta 7:
http://www.autopano.net/forum/p58278-2010-02-03-13-37-57#p58278
Agreed - this was discussed later in that same thread.
Why not record your request in this topic?:
http://www.autopano.net/forum/f24-the-future
by gkaefer » Thu Feb 11, 2010 11:27 am
BrianLR wrote:I find that with APT 1.1.0 Beta 7 - the Thumbnail window pops up on loading, this did not happen with beta 6 , is this intentional, it would be best if the was an option that could be set rather than happening whatever.
and in #30 of the above mentioned thread you can see my solution, so the default behavior can be changed...
http://www.autopano.net/forum/viewtopic.php?id=8222&p=2
Liebe Gruesse,
Andrew: thanks didnt know it ;-)
so diret link to #30 is: http://www.autopano.net/forum/p58446-2010-02-06-04-02-09#p58446
by mediavets » Thu Feb 11, 2010 12:33 pm
Liebe Gruesse,
Here's a direct link to post #30:
http://www.autopano.net/forum/p58446-2010-02-06-03-02-09#p58446
FYI - the date/time on each post provides a direct link to that post:
