Autopano Tour viewing question
johng
by johng » Thu Feb 11, 2010 3:54 am
Is there a way to make the panos "less distorted" for the viewer? The edges seem to pull and stretch when you rotate the Pano...
eg. http://myvt.ca/panotest/front.html
I would like it to be more of a Panning Motion then a spinning motion..
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Thu Feb 11, 2010 6:33 am
Did you try to change zoom level ?
Vincèn
Blog: http://www.skivr.com
johng
by johng » Thu Feb 11, 2010 12:26 pm
Good Morning,
I did that works - BUT I don't want the viewer to pan up and down and all around - Just move left and right... If there was a way to change the Arc of the Pan - That would be PERFECT!
John:D
by mediavets » Thu Feb 11, 2010 12:41 pm
johng wrote:If there was a way to change the Arc of the Pan - That would be PERFECT!
John:D
I don't understand what you mean by 'change the Arc of the Pan'.
If you don't want to allow 360 degrees of rotation horizontally then crop your pano in APP/APG before rendering so the pano HFOV is less than 360 degrees.
hankkarl
by hankkarl » Thu Feb 11, 2010 6:16 pm
The distortion is normal when you go beyond 90 degrees or so. Looks like you are at 120 degrees HFOV?
Use a 4:3 window so the view area is narower.
johng
by johng » Thu Feb 11, 2010 6:23 pm
Ok - Thanks I will try that
