flashing hotspots do not change in plan
digiherby
by digiherby » Tue Feb 09, 2010 4:05 pm
hello friends,
Tour will be better and better!!
One bug found: The flashing points do not change when you change the panos with thumbnails or within panohotspots!
greetings from Austria
herbert:):):)
digiherby
by digiherby » Tue Feb 09, 2010 4:06 pm
digiherby is using for professional use with mac pro 8 core.
Adrien F
by Adrien F » Wed Feb 10, 2010 9:15 am
corrected! ;)
jpdeglet69
Liked in: 6 posts
by jpdeglet69 » Mon May 31, 2010 9:22 am
Adrien F wrote:corrected! ;)
Corrected in which beta version ?
JPhD
Best Regards,
Eléana
JPhD
Adrien F
by Adrien F » Mon May 31, 2010 1:28 pm
beta 8
jpdeglet69
Liked in: 6 posts
by jpdeglet69 » Tue Jun 08, 2010 4:47 pm
Adrien F wrote:beta 8
Ok Adrien,
Waiting the new beta, I've modified XML coding,
for each pano.xml, I've completed the header
<krpano version="1.0.8">
<events onloadcomplete="playbackgroundsound(none);"/>
with
<events onloadcomplete="playbackgroundsound(none);selectmapspot(mapspotn);"/>
where mapspotn is defined according tour.xml
So,
In local, it's running well,
but online, synchronisation between pano and map doesn't run sometimes...
Have a look on
http://www.cosi-consulting.ch/jphd360/LeCrochet/LeCrochetSup.html
http://www.cosi-consulting.ch/jphd360/LesOublis/LesOublis.html
Why,
- sometimes ?
- is the event driven "onloadcomplete" not relevant to perform the "selectmapspot action".
In KrPano Documentation, I don't found the list of attributes possible for <events ...
BR
JPhD
Best Regards,
Eléana
JPhD
jpdeglet69
Liked in: 6 posts
by jpdeglet69 » Wed Jun 09, 2010 8:46 am
Ok Adrien,
with
So,
Have a look on
Why,
- sometimes ?
BR
JPhD
I've replaced event "onloadcomplete" by "onxmlcomplete" according KrPano forum...
Like that
<events onxmlcomplete="playbackgroundsound(none);selectmapspot(mapspotn);"/>
BR
JPhD
Best Regards,
Eléana
JPhD
Adrien F
by Adrien F » Wed Jun 09, 2010 1:16 pm
The modifications you have made are correct and the behavior I can see on your online version is also correct... :/
So I don't have any convenient answer to your problem.
You can let on loadcomplete, so the flashing hotspot will change after the loading of the panorama completed, and not at the begining.
About the krpano documentation, his online doc isn't complete now but he is working on it. You can find most of what you need for newest version by reading the releasenote.txt file in the krpano package on his website (download page).
