View limits
View limits
by mediavets » Mon Feb 01, 2010 3:40 pm
There occasions when I would like to limit the view - for example to prevent the nadir area being viewed.
It is easy to set such limits in Pano2VR.
I know that krpano has the capability of doing this but I have not found this capability to be supported in/via APT.
Have I missed something?
If it's just not there, please consider adding this capability ASAP.
digipano
by digipano » Mon Feb 01, 2010 5:29 pm
I remember doing a test sometime ago & only way to limit was to edit the xml files, Its a very basic requirement & should be available in APT.
by mediavets » Thu Feb 11, 2010 9:45 pm
I am bouncing this in the hope that we may get some response from the dev. team.
Adrien F
by Adrien F » Fri Feb 12, 2010 10:48 am
This is noted.
But it won't be part of our short term main development.
krpano to fix this for those who want:
<view ... vlookatmax="value" .../>
where
[font=monospaced]value = fov/2 - angle_of_nadir[/font]
In the case of 360x180 pano : [font= monospaced]fov=90[/font] and a reasonable value to avoid nadir is 10. So [font= monospaced]value="35"[/font] worked fine for a little nadir hole.
by mediavets » Fri Feb 12, 2010 11:04 am
Adrien F wrote:This is noted.
I am disappointed. I feel it should be.
It is implemented in a very intuitive way in Pano2VR.
b4de4nd
by b4de4nd » Mon Jun 14, 2010 8:04 am
this would be great to have as an feature in apt for those who dont need the nadir shot, or dont wanna clamp a logo on the bottom of the image...
