READ THIS BEFORE POSTING
Adrien F
by Adrien F » Mon Jan 11, 2010 4:11 pm
Since January 2010, this forum is dedicated to "APT Bugs & Discussion" topics only, no matter which version you use (stable or development). Such topics usually are posted by users, who found an issue in the software. Do post any bug reports, stability issues, crash reports, etc.
Any ideas you may have for a future Autopano Tour version belong in The Future forum.
Please write in the subject of any new topic the version of APT used. Like this:
[APT 1.0.6]My bug
or
[APT beta 6]My bug
And remember : one problem, one topic. This way we all can easily navigate the forum and search for answers.
Thank you
by klausesser » Fri Aug 27, 2010 4:24 pm
jlcarves wrote:[AutoPanoPro 2.0.9] Windows XP SP2 2Go RAM 1To Disk
No pb to detect panoramas out of RAW images (NEF) coming from my Nikon D300 but when lauching the rendering I got a critical error with the msg :
Error reading F:/hkjhk/XXX4424.NEF
Error GFL: "GFL_ERROR_BAD_BITMAP"
File: C:/Documents and Settings/Admin/Local Settings/Temp//KOLORAPP00984_...........tif
followed by another critical error
Error reading F:/hkjhk/XXXYYY.NEF
Error GFL: "GFL_ERROR_NO_MEMORY"
File F:/hkjhk/XXX4425.NEF
If anybody has a clue ....;-(
Thanks in advance,
Jean-Louis
Hey Jean-Louis!
APT doesn´t take RAW! It would make absolutely no sense!. Use TIFF or JPG.
