APT 1.1.0 beta 6 bug: only one lens flere viewable
Liked in: 14 posts
by gkaefer » Wed Jan 06, 2010 7:07 pm
posted some days before this APT bug & discussion was created under:
http://www.autopano.net/forum/t7994-apt-1.1.0-beta-6-bug-only-one-lens-flere-viewable
Liebe Gruesse,
Adrien F
by Adrien F » Thu Jan 07, 2010 9:46 am
Hi Georg,
Sorry for the answering time. This was indeed a bug, corrected as soon as you mentioned it. Will be available in next beta.
For the moment : edit your pano xml file and name each lensflare plugin differently (instead of actual "LENS" name).
    <lensflare name="LENS0" set="DEFAULT" visible="true" ath="328.53" atv="-9.28248"/>
    <lensflare name="LENS1" set="DEFAULT" visible="true" ath="381.128" atv="-8.92547"/>
    <lensflare name="LENS2" set="DEFAULT" visible="true" ath="362.05" atv="-20.1716"/>
digipano
by digipano » Thu Jan 07, 2010 10:08 am
Thanks Adrien,
any time line when will be the next beta available?
Liked in: 14 posts
by gkaefer » Fri Jan 08, 2010 6:24 pm
Adrien,
no Problem, just read your answer today ;-)) good to hear this get solved in next beta...
... solution is easy & works perfect.
Liebe Gruesse,
EDIT: is solved with beta 7 version out since yesterday...
