Thumbnails dont work as set in parameters, only 1 will show
digipano
by digipano » Wed Jan 06, 2010 4:11 pm
I cant have thumbnails shown in the tour with APT 1.1 beta 6
only 1 shows what ever I set thumbnail dimensions to either fix pixel size or to % size but all I get is just 1 thumbnail.
Win 7 x64
4gb ram
any other data required?
digipano
by digipano » Wed Jan 06, 2010 5:12 pm
I tried with 3 images this time & still get to see 1 thumbnail only, there's got be some reason for this bug.
by klausesser » Wed Jan 06, 2010 6:31 pm
digipano wrote:I tried with 3 images this time & still get to see 1 thumbnail only, there's got be some reason for this bug.
Did you change the order of the folder´s contents after generating the file in APT?
digipano
by digipano » Wed Jan 06, 2010 6:35 pm
No nothing changed but surprisingly I tried another tour now which only had 6 images & now the thumbnails work like they work in your case.
So may be there is a limit as to how many thumbnails we can have in 1 tour, the tour in which I am failing was having 28 images , so I dropped few & tried with 18 images & 4% width but that does not work either so it seems some kind of bug or limit is set not sure so I cant confirm this.
by klausesser » Wed Jan 06, 2010 7:00 pm
digipano wrote:. . . the tour in which I am failing was having 28 images . . .
Good Lord . . . . who would view a tour of 28 nodes? ;)
digipano
by digipano » Wed Jan 06, 2010 7:01 pm
This one is a mystery to me now.
I tried another set of images & added 17 of them to make a new tour & now all work fine from these set so don't know why only a certain set is not working with APT to show thumbnails.
Wild guess, the problem set of images are stitched with PTgui, could that be the reason? though I have checked they all are equirectangular & should work but for some reason they don't.
Its not really a bug but under certain conditions it produces no thumbnails.
digipano
by digipano » Wed Jan 06, 2010 7:03 pm
Well how else would you do a tour for a big hotel or large properties?
by klausesser » Wed Jan 06, 2010 7:18 pm
concentrate on the 10-15 most impressing places - not even a big hotel or a large property is impressing all over.
"Less is more!"
Just my 2cents :cool:
digipano
by digipano » Fri Jan 08, 2010 4:36 pm
Problem solved but the issue remains a mystery.
The images were on my desktop folder I moved it to another disk partition & now thumbnails work fine, does it point to a possible bug???
digipano
by digipano » Sun Jan 24, 2010 5:49 pm
Klaus from krpano answered the issue & yes all my problem images were having numeric in beginning that was causing the thumbnail issue. Dont use number as your file name at start.
klaus.krpano wrote:the "name" of an element in krpano must begin with an alphabetic character!
when a numeric character is used as first character, then the name will be
interpreted as "index", in your case now always "54", therefore only one thumbnail,
I don't know why everything starts with "54f" in your example, but try just adding
an alphabetic character in front of it (e.g. "x54f") then it will work,
best regards,
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=1960
