Swoody wrote:One more thing - (probably should start a new topic for it) , but I also notice that it keep trying to place my old LOGO, under that option. I think THAT makes it crash sometimes, because if I don't realize it and remove it (EVERY TIME!!) it says it can't "find it". I am trying to NOT have a logo, since they do not translate the way I want
Swoody wrote:Hi Andrew,
No pattern thus far that I can see, but it does frequently crash when I try to quit out of it, if that makes any difference.
I've tried it on 2 separate images - The JPEGs are 55 to 75 Mb when compressed, 165 to 280 Mb when uncompressed, respectively
Thank you! Sara
No pattern thus far that I can see, but it does frequently crash when I try to quit out of it, if that makes any difference. Sara
When installing new versions of APT betas, I always just REPLACE the old with the new. What is the best method for uninstalling - what files or preferences should I be looking for (to delete), since at least with the Mac version, there is no "uninstall" program?
Swoody wrote:These are full 360s. What is the optimal size for the files one should use as a starting point when creating tours?
